Cats Forever
Hello Bullet,
Are you referring to the wear plates that fit under the bearing blocks and on top of the rails? Those wear plates should keep the idler square with the track or you will get a lot of wear on one side of the idler. The wear plates allow the idler to move back and forth on the rails. Can you post a pic?
