D4 7U Final Drives leaking
power stroke 99
Send a private message to power stroke 99
Does anyone know if their is a way to adjust something without a major repair, or an additive that I put in the final drives to seal it up?
Tue, May 25, 2010 9:11 AM
ag-mike
use it, it may stop leaking, if not keep 'em full till you find a adjustment spanner. they mostly leak because its not used. good luck
Tue, May 25, 2010 9:34 AM
power stroke 99
Reply to ag-mike:
Thank you.....I will try that......what adjustment spanner are you talking about?
Tue, May 25, 2010 5:59 PM
gemdozer
Thank you received: 25
Reply to power stroke 99:
If he is leaking inside the sprocket there are no adjustement the seal has to be change
but if it outside you can adjusted the seal with the holder and the end nut.
Tue, May 25, 2010 6:30 PM
ag-mike
Reply to gemdozer:
get the tractors operator manual about the spanner and its use.
Tue, May 25, 2010 8:19 PM
power stroke 99
Reply to ag-mike:
It is leaking from inside behind the sproket and leaking out of the two large holes on the bottom of the inspection plate for lack of better terms.
Wed, May 26, 2010 7:55 AM
gemdozer
IF he is leaking bihind the sprocket you need to removed the sprocket and change
that seal and if he is leak at bottom the inspection plate should be worn or the large
hole should be the vidange plug is loosed
Wed, May 26, 2010 5:23 PM
power stroke 99
Reply to gemdozer:
Thanks, Will I need to pull that plate to tighten the plug?
Wed, May 26, 2010 5:57 PM
gemdozer
No just clean that plug in center and with ratchet 1/2 or 3/4 head for tighten and its maybe a exagon head.
Wed, May 26, 2010 10:55 PM
