D4, 7U fan belt replacement
D4gyppo
Send a private message to D4gyppo
I have a D4 7U series with factory front hydraulic pump for the blade. I need to replace the fan belt, do I have to pull the radiator and hydraulic pump off to do this? I hope not! Any help is appreciated.
Sat, Jun 2, 2018 9:06 AM
bursitis
http://www.fennerdrives.com/powertwist-plus/
These work pretty good. especially on the slow running old engines. adjust tension normally.
if you wish to replace with OEM then you will need to separate the drive coupling from the front engine pulley then install the new belt
Sat, Jun 2, 2018 9:35 AM
Paso Bob
Reply to bursitis:
No, you do not. The coupler separates by taking the six bolts off and driving a chisel between them to slide it back. Use the Google search function in the upper right corner. There was a post on this a couple of years ago.
Mon, Jun 4, 2018 12:06 PM
kracked1
Reply to Paso Bob:
Paso Bob is correct.
Mon, Jun 4, 2018 7:39 PM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
