D4 7U fan belt
D4 7U fan belt
power stroke 99
Send a private message to power stroke 99
I bought a new fan belt from cat, I figured might as well change it since everything was tore apart...........well the belt says 1 1/16 wide x 50" long.......it will not fit........it is to short by like an inch.......part number is 4F7956....Is this the correct belt?
Tue, Oct 13, 2009 6:58 AM
Depends on what pump pulley set up you have with your mix and match.
I don't have the belt dimensions but 7U prior to sr. # 27284 has different fan hub and ring (uses the 4F7956 belt) then the later ring and hub that uses the 5H4239 belt.
Tue, Oct 13, 2009 9:12 AM
power stroke 99
[quote="Old Magnet"]Depends on what pump pulley set up you have with your mix and match.
I don't have the belt dimensions but 7U prior to sr. # 27284 has different fan hub and ring (uses the 4F7956 belt) then the later ring and hub that uses the 5H4239 belt.[/quote]
Ok.....thanks.......I ended up using my old belt for now.
Tue, Oct 13, 2009 9:24 AM
Does anyone know of a non-CAT source for the 4F7956 fan belt used on a D4-7U prior to s/n 27284?
Mon, May 19, 2025 8:42 PM
Busso20
Thank you received: 31
A dealer should be able to give you the length and the section if you get the right person
Tue, May 20, 2025 9:28 PM
Thank you received: 54
if you search that part number on parts.cat you might find the info
Wed, May 21, 2025 6:35 AM
