D4 7u dash part
D4 7u dash part
Jimmy977
Send a private message to Jimmy977
Hello folks,  I'm wondering on d4 7u dash, is there a cover over the magnito that is part of the dash. I have parts book, it shows dash in profile, I'm not sure if there's a cover plate?
Tue, Sep 17, 2024 11:30 PM
Thank you received: 77
There might be Jimmy - the only one I've seen is my buddy's HT4 and there's an opening but I don't remember if there is provision to mount a cover. In any case, it's pretty tight in there behind the air cleaner. Another Cat design "win"....
Tue, Sep 17, 2024 11:57 PM
Jimmy977
Ok Neil, this D4 I purchased is very complete. The air cleaner was off when I bought it so I really noticed the hole in dash. If there was a cover originally, I think it is the only part missing from this machine. Thanks.
Wed, Sep 18, 2024 2:31 AM
RobertShaver
Send a private message to RobertShaver
Thank you received: 8
Reply to Jimmy977:
no cover for that opening. I have seen some real early J series D2's with a cover over the mag hole but never on a 7U D4
Wed, Sep 18, 2024 9:25 AM
josh
Thank you received: 14
Reply to Jimmy977:
If your dozer was equipped to have a cover plate for the mag hole in the dash, there would be a slot above the hole, and a bolt hole with a nut below the square access hole.
The cover plate was available for at least some of the J model D2s but I don't see any of the other tractors equipped to accept the cover.
I do have one on one of my D2 Js, they are a pain to put on and of no real use, and on the U models might be impossible to put on or remove without pulling the air cleaner and would not be removable with the crossover pipes for the dozer in place.
Wed, Sep 18, 2024 9:31 AM
Thank you received: 288
Reply to josh:
Scott Flint (RIP) had made some stainless steel cover plates in the past. I agree with Josh, a bit of a pain to have and the air cleaner is usually in the way. It would make the dash a little tidier (no spark plug ends visible.
Now I am thinking the direct electric machines would not have the pony flywheel cut out as well as for the magneto...smooth. JM
Wed, Sep 18, 2024 9:21 PM
