Hey D4 4me,
The gauge is telling you it's time for a service on fuel filters. I usually start at the inlet to the transfer pump and clean the check valve and stretch the spring a little. Then pull the filters out of the fuel tower and drain the tower. Give it a good cleaning. Install new filters after filling tower with clean fuel. They are other ways to bleed the system, but your ahead of the game if it's full before sealing it up. Then bleed the air out of tower. Next make sure you bleed the injector pumps on the back side of the injection pump. Next bleed the air out of the injector lines.
Good job on noticing the gauge informing you the fuel filters need attention.
Glen
thanks glen much appriciated
If you have not run out of fuel you don't have to bleed the injectors just make sure you bleed the filter housing before you open the throttle.
Hey D4 4me,
Glen
