D4-7u & d4-2t
D4-7u & d4-2t
Showing 1 to 7 of 7 results
Christopher
Send a private message to Christopher
I have a 1950 d47u that is missing a lot of parts and is a mess. It has an adjustable blade and a d4 winch. I just ran across a 1944 d42T that is complete but had the blade and winch removed. Would my part interchange? Not just the blade and winch but would the under carriage other stuff interchange?
Thu, May 17, 2018 11:55 AM
Lots/most parts will interchange. I am certainly no authority on D4's but I think the outboard track frame support is different and things related to the engine controls and air intake are different.
Fri, May 18, 2018 1:37 AM
Christopher
I was hoping that my bar, blade and under carriage would be interchangeable. Oh, and I hope the winch mounts too.
Fri, May 18, 2018 9:59 AM
WA7OPY
Send a private message to WA7OPY
Reply to Christopher:
The 2t is a narrow gauge and the 7u is wide, so there will be problems with the c frame. The 7u track pads will be to wide for the 2t. My 2t has 13 inch pads and there is little room to the tractor side panels . By what the parts book shows most everything will switch.My 2 cents.... WA7OPY
Fri, May 18, 2018 10:23 AM
Paso Bob
Reply to WA7OPY:
Not all 2T's are narrow gauge. I had one for years and it was a wide gauge.
Fri, May 18, 2018 10:47 AM
Christopher
Reply to Paso Bob:
[img]http://www.acmoc.org/bb/attachment.php?attachmentid=75721&d=1526622651[/img]
This is the 1944 D4-2T
[img]http://www.acmoc.org/bb/attachment.php?attachmentid=56101&d=1451423861[/img]
And this is my 1950 D4-7U
Sat, May 19, 2018 3:47 AM
Yes on the winch transfer seeing that the 7U is a side tank model. Much more complicated to adapt the winch to a seat tank model. Assorted parts will interchange including complete engine assemblies. Track frames are different in that your 2T is before the large outer sprocket hub change.
Sat, May 19, 2018 4:00 AM
Christopher
[img]http://www.acmoc.org/bb/attachment.php?attachmentid=56104&d=1451423913[/img]
Here's the old winch. It was soo hard not to do a joke there.
Sat, May 19, 2018 9:13 AM
