D4 7U Cutting edges part numbers
Showing 1 to 10 of 21 results
dannygcat
Send a private message to dannygcat
Does anyone have the part numbers for the D4 7U straight blade cutting edges? Also what is the bolt number? Thank you.
Sun, Sep 14, 2008 10:49 AM
SJ
Send a private message to SJ
If no one comes back with the numbers just stop into your Cat dealer and get them.I,m sure OM on here has a book with the numbers so maybe he will chime in now.
Sun, Sep 14, 2008 5:57 PM
Thank you received: 39
Reply to SJ:
What is the blade serial number??? Tag or stamped on the back right hand side near the top of the blade.
Sun, Sep 14, 2008 10:55 PM
Willie
That would be a 4A???? the only 60 in.ga. straight blade made in USA for the 7U. - Corner bits 9F7073(r.h.heavy duty)- 6F7074(l.h.heavy duty) or 7F7221(r.h.)-7F7222(l.h.) - Gutting edge 3F6575 or 6F1347(heavey duty) - Bolts 3F5108
Mon, Sep 15, 2008 7:59 AM
Reply to Willie:
The later 67E series straight blade will also fit the 7U.
Mon, Sep 15, 2008 9:52 AM
OzDozer
The three US-built, 4S (straight) blade models for the D4 are .. 2A1001-up, 4A2001-up, and 67E0001-up. These translate into modern Cat part numbering as 02A01001-up, 04A02001-up and 67E00001-up ..
Tue, Sep 16, 2008 2:37 PM
Willie
Reply to OzDozer:
The 2A was for a 6U not a 7U and the 67E was first made 20 yrs after the last 7U was made
Wed, Sep 17, 2008 6:29 AM
Reply to Willie:
The 67F1-up and 67E1-up are narrow and wide gage blades used on the 39A and 40A D4's starting 1959.
Wed, Sep 17, 2008 7:17 AM
Willie
Show me where the guy said he had a 39A or 40A, what I read says D47U straight blade. It may have a toolbar blade on it. Sure the others will fit it and about 50 others will fit it too, but only 1 made by Cat for the D47U
Wed, Sep 17, 2008 10:12 AM
Reply to Willie:
I'd be interested in knowing about that other 50 that interchange.
Wed, Sep 17, 2008 10:22 PM
OzDozer
You can squabble at length about what fits what .. and if you have enough determination .. you can make many a blade, fit a tractor it was never intended for .. however, at the end of the day, dannygcat still hasn't yet got his cutting edge and hardware numbers .. so here they are .. 😊
Cutting edge P/No's - D4 & D2 .. http://img171.imageshack.us/img171/4978/cuttingedges1cd3.jpg
End bit P/No's - D4 & D2 .. http://img117.imageshack.us/img117/5946/cuttingedges2np9.jpg
Thu, Sep 18, 2008 8:00 AM
