D4 - 7U Clutch Adjustment looks nothing like the manual
SkyMoCo
Send a private message to SkyMoCo
I have a pair of 7U with serial numbers 12915 and higher.    The clutch adjustment looks to be a yoke with a rod (see picture) and that doesn't look like the manua at alll.   Do I pull off the yoke and turn it to adjust it?
Pictures attached:
  [attachment=76483]20240521_122851.jpg[/attachment][attachment=76484]20240521_121503.jpg[/attachment]
Wed, May 22, 2024 2:33 AM
Thank you received: 53
Hi, SkyMpCo.
I have never been inside a U series D4 clutch compartment. How-wevver, if it is like the earlier 2T and 5T series, there is a locking clamp with a bolt in it just behind the clutch itself and ahead of the yoke. Those clutches were adjusted by loosening the clamp bolt and turning the pressure plate a little until good pressure was felt on the clutch lever, then re-tightening the clamp bolt.
I believe there is a specification for pounds of pull at the top of the lever but have no idea what it is.
Wed, May 22, 2024 6:16 AM
8C 361
Hi, SkyMpCo.
You will need a 3/4" socket with a universal to get at that nut. You may find it easier to go in through the bottom cover.
Wed, May 22, 2024 8:33 PM
kracked1
Reply to 8C 361:
Deas is correct on the adjustment.
Wed, May 22, 2024 10:00 PM
