D4 7U bulldozer Engine question
Showing 1 to 9 of 9 results
bess53
Send a private message to bess53
Hello,
New to the site! We just purchased a D4 7U Dozer The machine serial # is 7U1229 and the Motor tag is 6U 6846 is that normal or has the engine been changed? it has a pony motor. What Cat engine size would the 6U 6846 be?
Thanks in advance for your help!
Wed, Sep 18, 2024 8:09 AM
Thank you received: 40
Hi, bess53.
Your engine has been switched at some point, not uncommon as the 6U and 7U series both had the same engines. Your engine is out of a later machine than yours but the same basic engine.
Wed, Sep 18, 2024 8:21 AM
bess53
Hi, bess53.
Thank you for the reply, what Cst engine size woul it be? Thanks again for your reply
Wed, Sep 18, 2024 8:54 AM
Reply to bess53:
Hi, bess53.
I am not sure but I think it would be a D315 engine at about 48 horsepower. Others here could tell you for sure.
Wed, Sep 18, 2024 9:01 AM
bess53
Hi, bess53.
Thankyou, Have a Great evening
Wed, Sep 18, 2024 9:15 AM
gemdozer
Thank you received: 12
Reply to bess53:
Yes these machine use a D315 MOTOR
Wed, Sep 18, 2024 5:37 PM
bess53
Reply to gemdozer:
Thanks for your help. I appreciate that!
Wed, Sep 18, 2024 7:05 PM
Thank you received: 33
Reply to bess53:
the difference between a 6u and a 7u is track width the 7 u is a wide track machine. apart from differences in the track drive and the track itself they are the same.
the engine in your came off the line 600 machines after ours.
Sat, Sep 21, 2024 6:26 AM
bess53
Reply to trainzkid88:
Wow! That amazing, Thank you for your info, have a great weekend
Sat, Sep 21, 2024 7:21 AM
PhilC
Online
[quote="trainzkid88 post=259421 userid=11838"]the difference between a 6u and a 7u is track width the 7 u is a wide track machine. apart from differences in the track drive and the track itself they are the same.
 [/quote]
The difference is the gauge not the track width. On my D6 4R and 5R both have the same width tracks but are different gauges. Differences between the two are the track frames, final drive housing and hub, dead axles, spring mounts and fenders.
Fri, Sep 27, 2024 5:16 PM
