D4 7U blade install
D4 7U blade install
Showing 1 to 6 of 6 results
Relic
Send a private message to Relic
G'day gents, can anyone tell me where I could find aftermarket tapered bolts (part no 3F9967) 3/4" 10 NC in Australia, I just called Westrac in Petth and they want $34 each + GST and shipping from the US! I need 24 of them.
Mon, Feb 13, 2023 12:23 PM
rax200
Hi Relic,
Are you positive that is the part number? Are these for bolting the cutting edges on?
If you have the serial number it make finding parts much easier
Regards
Mon, Feb 13, 2023 4:57 PM
Thank you received: 53
Reply to rax200:
Hi Relic,
Regards
Hi, Relic.
Are you needing actual TAPERED bolts or are you talking about countersunk head bolts, such as are used for cutting edges?
If you are referring to countersunk head bolts for cutting edges, etc., any supplier of cutting edges should also be able to supply the bolts.
Mon, Feb 13, 2023 10:09 PM
side-seat
Thank you received: 8
Hi, Relic.
Or does he want the tapered bolts that hold the lifting assemblies to the track frames?
Mon, Feb 13, 2023 10:34 PM
josh
Thank you received: 7
Reply to side-seat:
3F6697.
https://aftermarket.express/caterpillar/3f6697
https://www.agkits.com/caterpillar-wheel-trunnion-bolt-3f6697.aspx#.Y-pd_XbMJnI
Mon, Feb 13, 2023 10:54 PM
Relic
Reply to josh:
3F6697.
I should have been more specific, I am chasing the bolts that secure the trunnion plates to the track frames.
Tue, Feb 14, 2023 5:57 AM
Reply to Relic:
Hi, Relic.
In that case, you want the bolts shown in the two links that Josh posted. Take your pick on the genuine Cat bolts or the cheap imitations.
Tue, Feb 14, 2023 10:13 AM
