D4-7U Accidently pumped grease into water pump purge value that looks like Zerk...
talley925
Send a private message to talley925
On my D4 I accidentally pumped 3 full pumps of grease into the water pump purge valve thinking it was a Zerk as they are shaped very similar. Will this hurt anything or just make a mess of the radiator fluid? It's tractor grease so it is somewhat resistant to water... What should I do?
Mon, Jun 10, 2019 9:00 PM
WA7OPY
Send a private message to WA7OPY
Run till warm ,add dish soap, run longer, drain and flush many times, look for soap bubbles if none add stop leak, antifreeze, water treatment , and water, look for leaks, have a beer.Don':tape:t do it again!!!....WA7OPY
Mon, Jun 10, 2019 9:50 PM
Thank you received: 61
Reply to WA7OPY:
Just run it. As soon as you take the grease gun off that relief, the grease "should have" oozed back out a little. It just provides relief to the chamber containing the two bearings and the two seals. This chamber and those seals only deal with grease. The water seal is a different seal separated by an opening to fresh air via the seep hole. So worst case is you might have pushed some grease out past the seal. Check that the weep hole is open underneath so any seepage from the water seal isn't impeded and you're good to go
Mon, Jun 10, 2019 11:03 PM
Oldcarman
Send a private message to Oldcarman
Make sure that the dish soap you use is Cascade or whatever you use in your dishwasher. If you put dawn or joy in there you will have a real mess on your hands.
About a half cup of powdered soap will clean it up.
Tue, Jun 11, 2019 9:44 AM
Neil is right, no chance you pumped grease into the coolant. I have seen several water pumps that had grease zerks installed in place of the purge fitting and the areas behind the fan pulley and in front of the water seal had lots of grease packed in there as evidence of over greasing way beyond an accidental few pumps! One had significant rust and damage to the rear bearing because the weep port between the water seal and the rear bearing and grease seal was apparently closed by dried grease, trapping moisture in that area.
If you do get oil in the coolant, the dishwasher detergent is the way to go. The dawn will work, just hard to get all the foam out.
Tue, Jun 11, 2019 7:32 PM
talley925
Thank you all for the input and advise. I'll run it a while to see what happens and drain it to see if there is any evidence of grease. If no grease got in the coolant then were would it go? Does anyone have pictures with the pump off by chance?
Wed, Jun 12, 2019 11:37 PM
Grease pushed out the shaft seals will accumulate behind/inside the fan pulley hub and or in the center of the water pump where there is a space between the rear grease seal and the water seal. This cavity has a drain slot cast or cut into the bottom of it so any coolant seepage will run out down the front of the engine before it can get against the grease seal.
Thu, Jun 13, 2019 12:19 AM
blwatson
Send a private message to blwatson
Talley, I do not know how to attach a link to a thread but if you do a search for a thread titled "D47U Water Pump Leak" there are some pictures that may help. I rebuilt my pump and Neil is completely correct with the info he posted.
Bruce
Thu, Jun 13, 2019 4:45 AM
Reply to blwatson:
Bruce
You could probably hide a tube of grease behind the hub and in the cavity between the bearings and the water seal. Just make sure that the weep hole is open and dig any grease that's easy to get out from that hole and don't worry about it
Thu, Jun 13, 2019 6:33 AM
