D4 7U 315 injection pump lifter setting
Suomalainen
Send a private message to Suomalainen
Would any one know what the injection pump lifter setting is on a D4 7U 315 engine? There was a previous discussion on a RD4 as being 1.734 but expect it might be different on the 7U series.
Tue, Nov 27, 2007 9:36 AM
Not much different😊 😊 Specs show1.736 in. for the 6U/7U.
Tue, Nov 27, 2007 10:04 AM
Suomalainen
Thank you Old Magnet for the 7U injection pump spec's. It is sure good to have you around.
Tue, Nov 27, 2007 12:03 PM
SJ
Send a private message to SJ
Reply to Suomalainen:
The .001 or .002 less won,t hurt anything & I usually set them at 1.735 & it would account for a little wear on the bottom of the pump plunger or even the screw surface.
Tue, Nov 27, 2007 7:23 PM
Suomalainen
Reply to SJ:
And thank you also Senior Member your advice is much appreciated.
Wed, Nov 28, 2007 3:28 AM
