D4 7u 14000 governor
kal
Send a private message to kal
I want to check the high idle speed. I found lo idle 550 rpm but can't find the high idle. I have the manuals,must be missing it. Thanks for any info.
k
Thu, Apr 2, 2020 9:48 PM
1525 high idle rpm gives 1400 full load rpm
Hour meter shaft turns half engine speed
Half would be 762.50 rpm
Thu, Apr 2, 2020 10:48 PM
kal
[quote="Rome K/G"]1525 high idle rpm gives 1400 full load rpm
Half would be 762.50 rpm[/quote]
Thank you!
k
Thu, Apr 2, 2020 10:51 PM
Reply to kal:
Thank you!
Your welcome!
Fri, Apr 3, 2020 4:20 AM
| Kingaroy, Queensland
