D4 7U 135xx bottom roller rebuild
d9gdon
Got a question about the bushing assembly in my roller that I’m rebuilding. My roller has the 7B2560 bushing assembly with the 1F2695 bronze bushing in it.
I ordered two used bushing assemblies thinking they would come with the bushings, but they sent 9F0593 bushing assemblies that have no bushings, and they’re made out of aluminum instead of steel with bronze bushes. The aluminum is machined to fit the shaft with no allowance for a bronze bushing to insert.
I see that it’s a replacement for my part number on General Gears website, but going back with aluminum concerns me. Being a weekend, I can’t just call to ask.
Is it a direct replacement and has anybody ran into this before? I had to weld up my shaft and turn it down as the roller was ran to destruction.
Sun, Nov 17, 2024 11:33 PM
Thank you received: 55
are you sure there not aluminium bronze. that comes in a range of grades and some are so tough they have to be cast and forged as they are tough to machine.
Wed, Nov 20, 2024 12:15 PM
d9gdon
Reply to trainzkid88:
No, they don't look to be. I went ahead and used them. I'll see how it goes. They fit nice after I rebuilt my shaft. I guess the question is whether they will last as well as the brass bushings did  as long as they are kept lubed.
Tue, Nov 26, 2024 2:18 AM
Reply to d9gdon:
well you would be surprised how well even a bit of hard wood will last as a plain bearing in low speed applications provided it kept lubricated.
Tue, Nov 26, 2024 4:18 PM
d9gdon
That's true on the wood bushings. So far, all is good after an hour and a half of run time.
Fri, Nov 29, 2024 9:14 AM
