d4 7u ?
Showing 1 to 10 of 10 results
clydecrashcop
Send a private message to clydecrashcop
Simple question, What year did caterpillar stop putting the pony motors in the d4 7u dozers? Thank you, Clyde
Sat, Sep 30, 2017 10:17 AM
They didn't. .........pony start was an option (if not standard) all the way through the u series and was available on subsequent series as well.
The later series ponies were a vertical 2 cylinder design that operated at very high rpm, and soon acquired the "buzz bomb" nickname! Those things probably hastened the final demise of pony motor start by several years.
Sat, Sep 30, 2017 7:05 PM
Thank you received: 105
Hi, Clydecrashcop.
As I understand it, the U series had pony motor start standard until the end of the run. As Ccjersey posted, pony motor start was still available on the later D4C's as a 2-cylinder vertical motor that ran at about 6,000 rpm and had a strong tendency to 'self-destruct'. Anybody who has a D4C with a 'buzz-bomb' pony motor would be well advised to junk the pony and install direct electric start.
Sat, Sep 30, 2017 7:34 PM
Bruce P
Thank you received: 26
Hi, Clydecrashcop.
My 78A D4D parts book shows the buzz bomb.
Ted Billups, one of my favorite local cat collectors, told me once. "I bet I've got an engine you've never seen", well he was right. He had a customer that had brought him a buzz bomb from a D6B. Ted went through it to make sure it was tight, then built a stand for it so he could display it. He would start it and run it for us. Pretty neat display.
BP.
Sat, Sep 30, 2017 9:42 PM
JackD6-5R
Reply to Bruce P:
BP.
I have a D6B that had the pony replaced with electric start because the buzz bomb blew up. It doesn't run needs left final.
Sat, Sep 30, 2017 10:32 PM
I think the best thing about the buzz bomb pony motors is they fit into the same hole as the direct electric starter. Just a shim piece installed in the hole and the starter will bolt right in.
Sun, Oct 1, 2017 1:46 AM
Dozerman51
The late series 7U's also came with or could be ordered with in seat start pony motors. I've seen and operated the in seat start pony motor 7u that 7upuller has. It is a real nice piece of Cat machinery. 👍
Sun, Oct 1, 2017 2:32 AM
Thank you received: 61
Reply to Dozerman51:
I'd like to see a picture of that arrangement, particularly how they've laid out the pinion, clutch, and decompression controls
Sun, Oct 1, 2017 3:50 AM
Thank you received: 257
The unseat arrangement is really nice. I have only seen 2 of these ever; Glen's and one at auction that neither D4e or myself was able to purchase. I was told by a fellow member that there were not very many of these ever made. Could someone shed light on how many may have had this option, and when were they made available? Thanks! JM
Sun, Oct 1, 2017 6:25 AM
Dozerman51
Check my thread to Glen below. Ianoz posted pic's of the set up on his 6U.
Sun, Oct 1, 2017 8:03 AM
Dozerman51
Old Magnet has a virtual reference library on the older cat stuff. He might have the Info your asking about? How about it Pete? What you say?
Sun, Oct 1, 2017 8:20 AM
