D4-7J4256 All of a sudden after 67 years.
Showing 1 to 10 of 11 results
BullDozerBob
Send a private message to BullDozerBob
I think this Cat has a plugged injector. Went to use it to pull fence posts with the blade and it started hard which is unusual, had no power at all, and no white smoke from the exhaust.
I bled fuel from the top of the injection pumps and all had fuel. What other ways are there to troubleshoot and can injectors be cleaned?
It seems to idle at low RPM OK but misses when the thottle is increased. The fuel pressure guage doesn't seem to be as high as usual so I will change the fuel filters today and see what happens.
Thanks in advance
BullDozerBob
Mon, Sep 1, 2008 9:06 PM
The best way to track down a faulty injector is to swap the suspect around to another cylinder and see if the problem follows. If all are affected that's another story.
Yes, you can clean the orifice of the injector if that is the problem.
Takes a 0.5mm drill (carefully) for the 4-1/4 in. bore engine (D4400)
Tue, Sep 2, 2008 8:19 AM
OCB
Send a private message to OCB
I got some moisture in the fuel and after six monthes I found out about the moisture and that things grow in the tank. I flushed the tank good and did my dozer work. I took the tank off and dried out and had it steam cleaned. After a couple rinses the tank seems fine but the filters were starting plug also.
Good luck. Clay
Tue, Sep 2, 2008 8:48 AM
SJ
Send a private message to SJ
Reply to OCB:
Good luck. Clay
What I found dozens of times is if a nozzle goes bad it will drive compression back into the whole fuel system through the bad nozzle and cause all kinds of problems so then the best thing to do is take them all out and have them checked or you can remove the nozzles one at a time and put the fuel line back on them and start the engine and see if you get a spray or just a stream coming out and that would be the bad one.Always keep the nozzles pointed away from you as that is pretty high pressure and can be dangerous.
Tue, Sep 2, 2008 6:43 PM
BullDozerBob
Reply to SJ:
Changed the filters and had a terrible time bleeding the filter tower-should have filled it b/4 bleeding but I'm old and forgot. Acts like its not getting fuel. Has no power at all then just takes off and runs fine for 10-15 seconds then loses power. Almost like the governor isn't working right? I don't have a parts book but remember posts a while ago talking about a spring that makes the fuel rack move to increase fuel. It has worked fine for 4700 hrs and 67 years.
Any input is appreciated.
Thanks,
BullDozerBob
Tue, Sep 2, 2008 9:37 PM
SJ
Reply to BullDozerBob:
Thanks,
BullDozerBob
Still could have some air in the fuel system yet so start at the filter base with the base bleeder and then the top cover bleeder and then go to each inj. pump and bleed them good individually and see if it helps the problem.
Tue, Sep 2, 2008 9:45 PM
BullDozerBob
Reply to SJ:
Took the cover off below the injection pumps and found #3 stuck in the up position--got it freed and it runs like a dream! There is a little rust on the sliding rods and the round ones --I cleaned them and everything slides well. Where do they get lubrication from? There is a reservoir below this area that I have changed the oil in. Got lucky!
Thanks for the replies.
BullDozerBob
Wed, Sep 3, 2008 10:01 AM
ol Grump
BullDozerBob
Glad ya found the problem. You'd think things would last more than 67 years, wouldn't ya? πŸ˜†
Wed, Sep 3, 2008 8:26 PM
BullDozerBob
Reply to ol Grump:
I was getting fuel at the inlet to all the injectors which threw me for a loop--thats why I thought an injector was plugged. SJ nailed it when he said wierd things happen to fuel systems. There are tubes off the top of the injectors--are they some kind of bypass? Anyway after I freed the stuck pump lifter and went to start the diesel it started on two cylinders and I had to bleed more air from all of them and the filter tower b/4 all cylinders fired. I'll see tonight if there is still air in the system when I fire it up. Can I use a litte greese to lube those slides below the injector pumps? I will change the oil in that reservoir below the pumps as well.
Thanks again.
BullDozerBob
Wed, Sep 3, 2008 10:27 PM
carlsharp
Send a private message to carlsharp
Thanks again.
BullDozerBob
Hey Bob that was exactly what was wrong with my 5T. I greased up everything before I put it back together.
CS
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: http://www.youtube.com/profile?user=carl4043
Thu, Sep 4, 2008 7:19 AM
Thanks again.
BullDozerBob
That "bypass" line is normally open to the ground. Any leakage from a worn injector is lost. It would probably be possible to return it to the tank if you had a bad leaker. I would hesitate to plumb it back into the fuel line before the transfer pump, just in case you got compression leaking back in at some point.
What ever grease you put on there should get flushed off eventually by the small leakage around the pump plungers. Sort of like a carbon pump seal, the seal is cooled and lubricated by the leakage across it. It doesn't seem to leak, but it has to leak just a tiny amount to survive.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeπŸ˜„
Thu, Sep 4, 2008 7:46 AM
