D4 7J main clutch
D4 7J main clutch
Showing 1 to 10 of 13 results
Tad7561
Send a private message to Tad7561
So my D4 7J needs a new clutch collar, brass shavings everywhere inside and I got a 10’ disk that my D2 won’t pull well. Can you change the collar without pulling the engine? I know to change out the clutch you need to. But I need to do just the collar.
Thu, Jun 8, 2023 11:02 PM
ChuckC
Send a private message to ChuckC
What kind of disk do you have? I had a 13' RWA John Deere disk that I pulled with my 5UD2 in 4th gear. You must have a big disked offset disk.
Chcck C
Fri, Jun 9, 2023 7:34 AM
Thank you received: 52
Reply to ChuckC:
Chcck C
remember discks are sized by the number off plates(discs) yes disc size makes a difference but not as much as the shear number of them.
Fri, Jun 9, 2023 7:45 AM
Tad7561
Reply to trainzkid88:
10’ offset with 18” blades, my D2 5J struggles with an 8’ offset. We don’t plow and don’t use a tandem. We use heavy offset disks One pass breaks and cuts in whatever I need it to.
Fri, Jun 9, 2023 12:33 PM
Reply to Tad7561:
so your only wanting to tickle the surface for pasture seeding etc
Fri, Jun 9, 2023 3:27 PM
Tad7561
No if I barely had the disk cutting I’d pull it with my farmall H. I need to cut fire breaks every year here.
Fri, Jun 9, 2023 6:33 PM
8C 361
Thank you received: 12
Reply to Tad7561:
I was able to change the clutch collar on an early 7U through small top cover. I got it from a 5T parts tractor. Everything was the same.
Used to pull 6' 9" disc with D2. Pulled 10' 6" offset with D4 but a little much in the hills. 9' 0" is about right but had to find anymore.
Fri, Jun 9, 2023 7:43 PM
Tad7561
 [attachment=72577]4ec4c4fce9f40a0fd60269f2f14d5efa[/attachment] Was hoping the collar could be changed through top access hole, thank you. This disk is all both my D2 can handle and this is the setting I have it and yes the disk is beat.
Fri, Jun 9, 2023 10:28 PM
ChuckC
Reply to Tad7561:
The pictures explain why the D2 would not pull it. I don't think my D2 would pull it either. Thanks for clearing that up.
Sat, Jun 10, 2023 8:12 AM
8C 361
Reply to ChuckC:
Il bet if you closed it up some more and chained it that D2 would pull it and it would still chop up the ground pretty good.
Sat, Jun 10, 2023 1:12 PM
Tad7561
Reply to 8C 361:
My D2 pull the disk in the second picture as is, the first picture with the TD6 is the 10’ disk I’ll need the D4 for.
Sat, Jun 10, 2023 9:11 PM
