D4 7J cracked oil pan
Showing 1 to 10 of 12 results
jmvmopar
My oil pan was cracked sometime in the past. The crack is in the equalizer spring area. The pan has been brazed up. What causes the pan to break, and is this a common problem.
Mon, Dec 28, 2015 10:18 AM
Very common problem. Comes from the really poor design feature of mounting the equalizer spring directly to the oil pan.
Mon, Dec 28, 2015 10:37 AM
Willowhic
Send a private message to Willowhic
Yup, OM is on the money. Cast iron is a rigid crystalline molecular structure and doesn't take shock loading or flexing well at all. It tends to have all the malleable and shock absorbing properties of a toilet bowl.
1988 JCB 1400B backhoe
1966 Cat D9 cable dozer
1966 Cat 980 wheel loader
1967 Galion 140 grader
1963 Cat D7E hydraulic dozer 47A886
196? Cat 112 grader 3U3308 (engine: 3U243)
Mon, Dec 28, 2015 11:55 AM
jmvmopar
Reply to Willowhic:
I get it's kind of a crappy design, but is there a remedy for this issue. Reinforcement? or simply replace with a hopefully good pan.
Thu, Dec 31, 2015 10:04 AM
Reply to jmvmopar:
Maybe some insulating material such as UHMW plastic or brass sandwiched in between would help.
Thu, Dec 31, 2015 10:21 AM
I would suggest an elastomeric pad of durometer hardness of at least 50 that is used in bridge bearings---either plain or reinforced with steel plates
Thu, Dec 31, 2015 10:45 AM
Sasquatch
Thank you received: 5
Reply to dpendzic:
Hey jmvmopar, I've got a pristine oil pan off of a D4400 power unit engine that I tore down for parts, it came out of a dragline. Actually now that I think of it I remember selling you the fuel pump drive gear from that engine a few years ago. It looks identical to a tractor oil pan, and has never touched a spring as the engine was mounted on skid type mounts. There is a "but" though, this D4400 is older than your 7J, it's from the 4G RD-4 era. I don't have the parts books or knowledge to verify if it would interchange with your 7J or not, but if it can be determined that it would, I would like to sell it and get it out of my shed, plus I'm not that far from you.
For what it's worth, by eye-balling the pan it looks identical to the one that's on a 5T near here, but of course that is far from conclusive. I can get the engine serial# and any casting numbers that might be on the pan if you're interested, but it's gonna have to wait for daylight first, lol.
Thu, Dec 31, 2015 11:18 AM
Reply to Sasquatch:
Takes a s/n to check!!!!!!
Thu, Dec 31, 2015 11:18 PM
Sasquatch
OK went out this morning and got some numbers and pics, engine serial #4H327SP. Snapped a couple pics of the pan too as long as I was into it.
Casting number and numeral code, likely inconsequential but just FYI.
[img]http://i802.photobucket.com/albums/yy310/TRNelson/photo%20203_zpsiivbankr.jpg[/img]
[img]http://i802.photobucket.com/albums/yy310/TRNelson/photo%20204_zpschyb47fy.jpg[/img]
[img]http://i802.photobucket.com/albums/yy310/TRNelson/photo%20205_zpsjcmjvs8l.jpg[/img]
Thu, Dec 31, 2015 11:55 PM
Reply to Sasquatch:
OK, that's half the s/n requirement, need the 7J s/n.
There is interchange but it takes a big jump to later 7J s/n's.
Fri, Jan 1, 2016 1:24 AM
jmvmopar
Sorry for the late reply. I had to run to Minneapolis last night, just got home with some new toys. Picked up a valve grinder and valve seat grinder set. I just couldn't pass up the deal. [attachment=32825]0101161524.jpg[/attachment][attachment=32826]0101161525.jpg[/attachment]
The serial number is 7J3168W. My parts book shows the oil pan number to be 4B5416
Sat, Jan 2, 2016 6:25 AM
