D4 6U track questions discussion
Showing 1 to 10 of 20 results
bursitis
i have a D4 6U of 1953 vintage. it is time to turn the pins and bushings so i called my local Cat dealer to see if they would do the job. they told me that it would be more economical to just replace the chains. this is where it gets interesting and i have a few questions.
1. my sprockets are fine and don't need replaced
2.my rails are the 6B4645 so they are the early type and the pads have 1/2 inch holes instead of 9/16 or 5/8
3. my rails are in spec for a turn and the grousers are fine and on the 6U are 13 inch. can't be any wider on the 6U.
so really all i need is a turn and reinstall but i am not against updating to a modern track group,but i think the new track assy will have bigger bushing diameter and might not have the proper shoe width either but unsure. question is will the newer style track chains work with my sprokets? is there an aftermarket that closer matches my original dimensions?
Tue, Mar 10, 2020 8:33 PM
The bolt holes will be larger on new rails, I dont know what Cat offers now but Berco has sealed rails, not lubed, that work well, not sure on track shoes though. It's not really worth turning pins and bushings on a small crawler, it's up to you, and depends on rail height also.
Tue, Mar 10, 2020 8:43 PM
bursitis
yeah i understand and agree. do you know the berco part numbers? if the bolt pattern matches i could always have the pads drilled for larger bolts but all of this adds expense. does berco rails fit the old sprocket dimensions?
Tue, Mar 10, 2020 8:57 PM
Reply to bursitis:
Yes Berco will fit the older sprocket, you can check with Mike Zimmerman he sells Berco I believe and has allot of old D4 knowledge. 573-378-7210
Tue, Mar 10, 2020 9:27 PM
bursitis
Thank you very much
Wed, Mar 11, 2020 12:55 AM
bursitis
Reply to bursitis:
Thank you very much
is Mike Zimmerman a member on this board?
Wed, Mar 11, 2020 12:59 AM
Reply to bursitis:
Cat lists the track with small bushings, sealed (4K3918 regular bushings) 6.75" pitch, 1/2" holes as Link assembly 4K7128 which is a 36 link version, remove sections as needed.
Wed, Mar 11, 2020 1:18 AM
Riverina d4
Send a private message to Riverina d4
[quote="bursitis"]i have a D4 6U of 1953 vintage. it is time to turn the pins and bushings so i called my local Cat dealer to see if they would do the job. they told me that it would be more economical to just replace the chains. this is where it gets interesting and i have a few questions.
so really all i need is a turn and reinstall but i am not against updating to a modern track group,but i think the new track assy will have bigger bushing diameter and might not have the proper shoe width either but unsure. question is will the newer style track chains work with my sprokets? is there an aftermarket that closer matches my original dimensions?[/quote]
If Rails are in spec I would look at Getting a track shop to fit new pins and bushes into your Rails, either genuine or after market.
Wed, Mar 11, 2020 1:29 AM
Thank you received: 71
Reply to Riverina d4:
My old track expert here said drilling out the pad holes using a masonry bit works best.
Good luck finding someone willing to do P and B on your old rails.
Occasionally one can get lucky and find a junked machine with decent UC, probably tougher for you with the need for narrow pads.
Wed, Mar 11, 2020 2:10 AM
Reply to bursitis:
Not that i'm aware of. I have done business with them before.
Wed, Mar 11, 2020 4:41 AM
4K7128 changes to 154-3656 $4001.57 EACH, from Cat. Must be SALT rails for that price.
Wed, Mar 11, 2020 4:44 AM
Newby Hall Tractor Fest
