D4 6u track pad bolt part number
Reisingerweld
Send a private message to Reisingerweld
Hey guys I've done a few searches and looked through the parts book to my machine which shows 3 different possible bolt and nut combinations for the track pads on my D4 6U, I pulled an old bolt out and it measures about 9/16x1-3/4. Does any one know the part number for that size track bolt and nut to match?
Thu, Oct 22, 2020 12:37 AM
Cat lists a 1 5/8" long bolt 4K7038 and 7K2017 nut. Yours was probably a hex nut and lock washer, Cat now uses the shorter bolt with the square nut now.
Thu, Oct 22, 2020 1:18 AM
Reisingerweld
Ok next odd ball question I saved a set of freshly rebuilt track chains and pads from the scrap yard but those like the book say only have 31 links/pads.....my old track on my machine actually have 32, both are 4 roller side frames....and my tensioner is not all the way out was there a different option for say a larger idler or somthing that allows for 1 extra link/ pad??
Just went to re- measure the bolt I took out it is definitely 1-3/4 long and had a square nut on it with no lock washer.
Thu, Oct 22, 2020 8:29 AM
Reply to Reisingerweld:
Ag tractors had smaller idlers than tractors equipped with a dozer arrangement. Are the bolt threads flush with the nut or out past when assembled?
Thu, Oct 22, 2020 9:23 PM
Reisingerweld
Some are flush some are out, whoever did the last "rebuild must have saved some of the older bolts that would use a lock washer.
I appreciate your help Rome, now to find 2 new pads to make a set for my tracks
Fri, Oct 23, 2020 9:26 PM
| Kingaroy, Queensland
