D4-6U "spring part"
D4-6U "spring part"
Orchard22
Send a private message to Orchard22
Hi,
I am looking for an odd piece, and to make matters worse it doesn't match the description in my parts catalog. So, here's my best shot at a description: Where the main equalizer spring meets the track frame there are two(2) vertical tabs that stick up on either side of where the spring rests on the track frame, and through both of those tabs, over the top of the spring, is a bolt going through what I can best describe as a "football" shaped piece that stretches from tab to tab. Does anyone know what this piece is actually called? ,and does anyone have one available for me to purchase?
Cheers!,
Orchard22
1935 Caterpillar
Twenty-Two Citrus(or low top seat orchard)
serial number:2F2204
Wed, Jun 13, 2012 4:24 AM
My D2 parts book calls it a sleeve. found it in the equalizer spring page
Cat has mine for $39.29 :jaw:
Wed, Jun 13, 2012 6:30 AM
ol Grump
Reply to dpendzic:
A few years ago I bought a D4 7U that had that piece missing on one side, not only was it gone but the tabs on either side of it were gone too. I cut a pair of tabs out of 3/8" plate, welded 'em on and took a chunk of 1 1/2" plate, carved a new piece, drilled the hole and installed it.
As I recall, the D4 J, T and U models all used the same piece (probably with different part numbers). You don't want to run without one on each side over the spring. .if the critter rares up it's possible it can flip the machine over.
Wed, Jun 13, 2012 7:32 PM
rotorbob
Send a private message to rotorbob
Reply to ol Grump:
I am sure I have 1 or 2 of those footballs that you need. Give me 1 or 2 days 2 find it, then u could come and pick it up.I am in Hollister.
Thu, Jun 14, 2012 4:17 AM
Reply to rotorbob:
I just used a piece of pipe with a grade 8 bolt thru it--will that work? what is the function of the football shape?
Thu, Jun 14, 2012 5:33 AM
STEPHEN
Reply to dpendzic:
Since the track frames oscillate and the spring does not in that plane, the tapered shape of the roller allows it to maintain better contact with the flat end of the spring & promote more even wear.
Thu, Jun 14, 2012 6:41 AM
Orchard22
Reply to STEPHEN:
thanks rotorbob!
my dad works in San Juan Bautista, so if I am able to catch a ride from him picking up the part should be no problem!
1935 Caterpillar
Thu, Jun 14, 2012 10:35 AM
rotorbob
Reply to Orchard22:
thanks rotorbob!
Cool, just send me a pm when u r ready 2 come.
Thu, Jun 14, 2012 5:45 PM
ol Grump
Reply to rotorbob:
In the "for what it's worth dept", once upon a time I had a couple of D2 J models and as I recall, they were a bit different than the D4's as far as those pieces are concerned. Both of the D2's had what looked like heavy wall round tubing instead of the "slipper" shaped parts on the D4's.
Thu, Jun 14, 2012 8:13 PM
