d4 6U and 7U track guards removal
captainhowdy
Send a private message to captainhowdy
I am trying to get the old track guards off of my 6U dozer with 4s blade . my question is>>> does the rear tower that holds the hydraulic cylinder have a cleat welded to the inner surface that pinches the rear track guard? there is almost 1/2 inch clearance between the rear tower and the gaurd except right at the rear corner of the tower. it gets real tight and when i try to chip away at the crud it sounds and feels like steel.
Fri, Jun 30, 2017 4:25 AM
Not sure we're talking about the same spot but there is a mounting block attached to the track frame just about behind the trunion mount. The attaching bolt for the guard at this location is inaccessible with the cylinder mount in place as there is not enough room to remove the bolt. One of my D4's has a small hole torched into the mount to access the bolt but normally this is not provided.
Fri, Jun 30, 2017 6:07 AM
captainhowdy
Thanks Magnet. I see what you are saying, there isn't room between the mount and the track guard to install the bolt. but what i am asking is toward the final drive. it looks like the rear most cover is pinched between the cylinder mount and the outer bearing housing on the final drive. have you ever removed the rear dirt guard on one of your D4?
Fri, Jun 30, 2017 6:33 AM
Hi ch,
you may get lucky if the person fitting the blade mount followed the Cat Instructions and slotted the bolt holes in the guards so you could loosen the bolts and slip the guard up off it/them.
We always did this at The Dealer way back when.
captainhowdy
Reply to edb:
Hi ch,
[quote="edb"]Hi ch,
Eddie B.[/quote]
Thanks Eddie. my guards are pretty rusted away down where the bolts go through and the bolts are all twisted off. I have new guards ordered from MA CAT so i will slot the new ones when i get the old dutchmen out and new bolts installed. i am having trouble where at the front corner of the rear final drive guard where there is much old compacted dirt packed between the hydraulic cylinder mount and the track frame. i think there might be a small block welded to the dozer mount to aid in installation that has the guard pinched. or is it just built up old dirt that has turned to concrete??
Fri, Jun 30, 2017 6:42 AM
Reply to captainhowdy:
[quote="edb"]Hi ch,
Eddie B.[/quote]
The mounting block isn't that far back.
Fri, Jun 30, 2017 8:40 AM
d2gary
[quote="edb"]Hi ch,
Eddie B.[/quote]
Similar situation on my D4 not sure because I didn't take anything a part but I did try to pull my guards out and have that concrete compact dirt in mine also. I dug with screwdrivers and pressure washer and couldn't get mine out. Really seems like they are pinched between the frame
Fri, Jun 30, 2017 10:31 AM
Paso Bob
Reply to d2gary:
I'm not sure what you mean. I installed the 4S side arms on my 7U a couple of years ago and where the bellcrank for lifting and lowering the blade is, it also bolts to the inside of the track frame with a heavy duty bracket. As far as the track guards go, I added those to my 7U also. They are heavy duty rock guards that keep the tracks from coming off in steep country, and the dozer arms and track guards are not connected. I didn't find any places I couldn't get a bolt in. Snap a picture or two and post them to further define what help you are needing.
Fri, Jun 30, 2017 11:14 AM
captainhowdy
Reply to Paso Bob:
sorry Bob i am talking about the dirt guards on the top of the track frame that cover the track adjuster center spring and final drive.
Fri, Jun 30, 2017 7:15 PM
