D4 5T Zenith Carby
D4 5T Zenith Carby
Showing 1 to 7 of 7 results
auscuscus
Send a private message to auscuscus
Can anyone help with a diagram of this older carby ? 1946 8B 3917 979CA
The symptoms say I have too much fuel coming in. Can only start with throttle off , wet oily plugs , half cap full of fuel out of drain cocks on each pull. Pull after pull with no ignition. Magneto is giving plenty of good spark.
I opened the carby to find the jet has snapped. See on second pic it sits in the dark hole. I take it this controls the amount of flowing from the float chamber into the body. I assume screwing it down blocks flow, but then it has pin hole a few mm up it shaft to give minimal flow regardless. Having said that it was sitting in position and should of restricted flow ?
I need to buy that screw jet and a new top gasket - any advice on supplier that does postal.
Is that called a soft plug under the float chamber ? ( see last pic ) How do I remove that to make sure that passage is free of crud ?
Cheers - David
Fri, Jan 22, 2010 12:51 PM
bruce oz
Thank you received: 23
hello auscuscus ,in the pic below you can see were the needle sit in the bottom of the bowl ,fuel would run out as quick as you put in there ,
carburetor show in the usa would be your best bet ,bruce oz
http://www.thecarburetorshop.com/Tractorkits.htm
[img]http://img44.imageshack.us/img44/6797/page050.th.jpg[/img]
Fri, Jan 22, 2010 1:17 PM
auscuscus
Thanks Bruce, I have emailed carburetor shop asking if that jet comes in the kit. I think I bought one from them about 5 years ago , but my memory has gone from smelling too much of this carby. Their codes rang a bell. Thanks for the image. It shows the soft plug I was asking about is lead. There are a couple of odd elbows coming off the carby in your image that I don't seem to have. See my pic in original post. Thanks again, David
Fri, Jan 22, 2010 6:38 PM
Thank you received: 95
Reply to auscuscus:
Hi David,
scan below is from OMI and all there is of the early carb operation and views--there are no descriptions of the fuel flow etc as for the later carb-- also scanned for your perusal.
Hope this helps.
Sat, Jan 23, 2010 9:20 AM
auscuscus
The carburetor shop cannot help with the main jet adjustment screw. Any other sources ?
Thanks for the pics Eddie. It is that main jet #14 in your first pic. I cannot braze it back on that straight.
Mon, Jan 25, 2010 12:20 PM
Reply to auscuscus:
Is it hollow all the way up? The top section does not have to be hollow, so put a short piece of rod or wire in it to align it perfectly and then silver solder it up.
If it's solid, I would try to braze it and then straighten if necessary, or perhaps have one made on a lathe.
Mon, Jan 25, 2010 12:31 PM
auscuscus
It is hollow at the seat section with a pin hole in its side that accepts fuels in and drops it out its base to feed the carby. Ie: screw it down and less fuel gets into the side pin hole. So too complex to turn one up .
The top is solid, where it has snapped , but brazing it that straight as needed ?....... I guess length can vary as the screw can cope with that.
Mon, Jan 25, 2010 10:51 PM
Reply to auscuscus:
What about a piece of steel brake line tubing on the outside to hold it straight?
Tue, Jan 26, 2010 1:50 AM
