D4_ 5T series 67701
D4_ 5T series 67701
Showing 1 to 7 of 7 results
geoff-derham-6202
Send a private message to geoff-derham-6202
G'day, I have purchased an old D4 and wondered if anyone new the build year and if there is a manual for the above model?
Geoff
Tue, Jul 22, 2025 1:52 AM
Msjoy
eBay has them
Tue, Jul 22, 2025 2:00 AM
Blue0xEF
Send a private message to Blue0xEF
Someone correct me if I'm wrong...
1945 D4 5T1 - 5T3523
1946 D4 5T3524 - 5T6780
1947 D4 5T6781 - 5T7411
Tue, Jul 22, 2025 1:34 PM
Busso20
Thank you received: 9
Geoff, join ACMOC, there is a lot of manuals in the library you can view as a member, they cover machine, hydraulic system, etc etc the list goes on
Tue, Jul 22, 2025 9:42 PM
Thank you received: 41
Hi, geoff-derham-6202.
Are you sure that you have the correct serial number posted? That 67701 number seems a little high.
Wed, Jul 23, 2025 1:25 AM
ChrisE
Thank you received: 11
Gday Geoff. What condition is your machine in. Is it going or need a bit of work to get it to go. If possible post some pictures we love looking at old Cats. I had a 2T and got the Jensales manual. The manual was good to follow but the pictures were very low quality. What part of the country do you habitat. Good luck with your toy.
Wed, Jul 23, 2025 3:29 AM
geoff-derham-6202
Hi all, thanks very much for the info. My apologies for the incorrect serial number, one extra number... it is actually 5T6770 so looks like it's a late 1940's I'm a ACMOC member so will have a look for the manual once I get the hang of using the Library:) I haven't tried starting it yet, I'm planning on flushing the radiator and changing engine oils first. In Victoria-Gippsland. Not sure if the attached 3 photos worked.
Very keen to get to it.
Thanks again
Geoff
Wed, Jul 23, 2025 9:35 PM
D8Dude
Thank you received: 6
Hi Geoff, I don't think we are too far away from each other, I've sent you a private message
Thu, Jul 24, 2025 2:15 AM
