d4 5t radiator surge
wvgca
Send a private message to wvgca
when warmed up my radiator level surges up and down probably two inches, and i have no idea why..
background .. did the engine, rings, bearings, exchange head etc... ran hot .. this spring removed pony, added electric starter... then removed top rad cap, rodded out rad, ran cold now, installed new cat thermostat, and surging started ... will not surge until run for 10 minutes or so, and temp gauge up to 140 / 160 area ..no bubbles in rad ....was wondering if installing block off plate on back of head after removing pup with bleeder water tap was giving me an air lock of some type or hot spot in the cylinder head??
any ideas appreciated
Fri, Jun 26, 2015 7:26 AM
Thank you received: 39
Lots of those D4400's have been converted to direct electric start without cooling issues. If there is no sign of air bubbles or boiling temperatures, I would suspect a restriction in the water circulation either from a malfunctioning thermostat or water pump issues. Did you rebuild the water pump along with your other work? Get one of those infra-red remote reading thermometers and go over the system operating temperatures.
Fri, Jun 26, 2015 11:02 AM
mrsmackpaul
Does it have a pipe that goes from the thermostat housing to the water to by pass flow the water when the thermostat is shut it might be rusted and blocked maybe ???
If it cools fine when the thermostat is open I would think the pump is ok
And you know the thermostats are working fine and shutting off ok but it sounds like the water has no where to go to me
Paul
Fri, Jun 26, 2015 1:56 PM
wvgca
Reply to mrsmackpaul:
Paul
just a couple of weeks ago, after the radiator was rodded out with no thermostat in place, the temp gauge would not move off the bottom, and engine would not warm up enough to run smoothly, so new cat thermostat / regulator was installed, new gaskets / o ring as well .. when it gets up to [gauge indicated] 140 to 160 F, the surging starts, no bubbles, just the level going slowly up and down, around 5 seconds to go up, same to go down .. water pump was not rebuilt recently.. but seemed to work fine without thermostat, gauge does not go higher than 180 [standing, appx 2/3 throttle], it's not boiling at all, there is no externally visible water bypass pipe, the thermostat is right at the very top of the casting maybe one inch away from where it bolts to the top radiator casting .. will be going out to the farm today again, and let it warm up a bit and give it the first oil change since rebuilt, only maybe three hours on it so far, but the rebuild was an inframe, and figure a $50 pail of oil is cheap insurance.. not sure if the surging is an air lock or just the thermostat opening and closing, water level is only 1/2 inch below top of rad ...i "think" i may have a non contact thermomter someplace, will try to find it and take it with me.. thanks
Fri, Jun 26, 2015 5:29 PM
ol Grump
Reply to wvgca:
From your description of the coolant "surging" I'd take a guess and say there's some air trapped in the system somewhere. If you have a hill, climb it and when you get to the top, check the coolant level. If it's down from usual, add 'til it's up to where it should be.
When I change thermostats, if there's not a small bleed hole in the plate I drill a 1/8" hole. That lets air in the engine bleed out as the radiator is refilled. The last two thermostats I got from Cat did NOT have the air bleed hole in 'em.
Fri, Jun 26, 2015 6:24 PM
Reply to ol Grump:
I was going to mention the 1/8" bleed hole but ol Grump beat me to it.
You can also use the automotive type simple thermostat and do the same bleed hole thing. I'd have to go dig around for the part number but it is a standard large flange regular automotive type that fits nicely into the radiator pipe neck flange.
Fri, Jun 26, 2015 10:02 PM
I'd be interested in that Part Number also!
Sat, Jun 27, 2015 12:58 AM
wvgca
Reply to drujinin:
i think it may have been an air lock... changed oil this morning, and drained the rad and block as i had some tsp in there to clean it out a little more... when i refilled with water it took the last gallon or so very slowly, and i could hear a bit of hissing.. i was going to try and loosen the pipe plug about 2/3 of the way up the thermostat housing casting, but only managed to round it off, will need heat later on..so i just worked it pushing some dirt at 3/4 throttle in second and the surging was still there easy to see as i dont have the right rad cap, just a piece of 3/4 plywood. the heat gradually came up to just over 200, and suddenly dropped to 160 and the surging stopped, ran it for about an hour after that at full throttle, taking some bigger bites to try and get the rings seated, only three or four hours on the engine now, temp was around 180 working and no more surging..oil pressure about 3/4 and fuel was close to full gauge, the factory cat thermostat that i got did not have a bleed hole...so i will probably just take out the one pipe plug and install a radiator petcock in there
thanks to all .. 😊
Sat, Jun 27, 2015 1:22 AM
Reply to drujinin:
The automotive type thermostat that works on the D4400 is a Stant #65478. It has a 2-1/2" diameter flange and is rated at 180 deg. F.
Sun, Jun 28, 2015 7:12 AM
