D4 4g Just picked up
griffen97023
Send a private message to griffen97023
Just Picked my first cat a D4 4g, Dropped it off at the house this morning, The first injector pump was frozen solid and the fuel rack would not move, Got that fixed, went to change the 4 fuel filters and it turns out they had been removed. Does anyone have a picture or any measurements so i can make up some rods to hold the fuel filters to the lid? what are the original ones made out of? Also about how strong should the springs be that is on top of each rod, it is all missing. Pony engine is not sparking, got the magneto all tore off letting dry out by the fire and going from there on that.
Mon, Feb 20, 2017 10:21 AM
Originals are a type of plastic and tend to be brittle. It doesn't take anything real precise, I have threatened to make some from 1/4" all thread with fender washers and lock nuts top and bottom to retain them. Might have to drill the holes in the top plate a little larger since the original rods were square so fuel more easily flowed around them through the plate. Any spring that takes a couple pounds to compress should do the job.
Mon, Feb 20, 2017 11:15 AM
griffen97023
thanks for the info, i really want to get this running to prove to my wife i didn't spend to much money on it. I wouldn't even try unless i got the filters in there.
Mon, Feb 20, 2017 11:26 AM
