D4 2T Steering Clutch
OCB
Send a private message to OCB
I pulled the winch off the tractor today. I looked in the rear inpection hole, to see a couple 9/16 inch ball bearing laying just to the rear of the Steering Clutch Compartment drain plug. Where could these have come from and which way is the best to inspect further.
I don't have a parts manual yet but can borrow a service manual.
As far as operation of the tractor, I didn't suspect anything from the few hours operated.
Thanks Clay
Wed, Apr 25, 2007 9:36 AM
The only ball bearings back there are for the steering clutch thrust bearings.
Wed, Apr 25, 2007 9:55 AM
OCB
Thanks for the detailed reply.
After a good inspection and coffee shop talk, it was determined that the previously owner had some steering clutch problems and repair.
No problems found. Thanks again Clay
Thu, Apr 26, 2007 5:20 PM
