D4 2T radiator core part number
dtcohen
Send a private message to dtcohen
Hi All,
I am about to order a new radiator core for my grandpa's d4. The serial number is 2T8853SF. From what I can find the part number for the radiator core is 2A1164, but I want to make absolutely sure that is correct before I have a new core made. Could somebody with a parts manual please confirm whether or not that is the correct PN? I have attached a picture of the tractor SN tag and the tag that is on the core of the radiator.
[attachment=40777]IMG_0009.jpg[/attachment]
[attachment=40778]IMG_1679.jpg[/attachment]
Thanks!
Daniel
Mon, Mar 20, 2017 8:12 PM
2A1164 is the radiator core for a 7J6436 to 7J7318.
4A0149 is the radiator core for 7J7319 to 7J9999, 2T1 to 2T9999 and 5T1-up.
Radiator assemblies often get swapped, make sure you have the right one.
Mon, Mar 20, 2017 10:15 PM
dtcohen
Thanks Magnet!
I looked up those two part numbers and it appears that they are interchangeable.
Tue, Mar 21, 2017 8:11 PM
Reply to dtcohen:
Thanks Magnet!
Yes, I looked at one of my aftermarket parts manuals and it shows 2A1164 covering 7J, 2T, 5T models.
Tue, Mar 21, 2017 10:28 PM
brian18a
Thank you received: 69
In many cases the low part numbers in the 4a series are WWII redesigns to save critical materials. Such as brass, copper, aluminum. Thus the 4a parts can be steel, or cast iron. In most cases after war parts reverted to original numbers and material, according to npr. Thus the 4a radiator core could well have been steel rather than copper.
An example of change in material, is the drive disc in my sixty with the diesel conversion, the drive disc on planetary was originally aluminum, this one had a cast iron one with a 4a number. Another planetary has an aluminum one, with a casting date in the late forties.
Tue, Mar 21, 2017 11:25 PM
dtcohen
Reply to brian18a:
[quote="brian18a"]In many cases the low part numbers in the 4a series are WWII redesigns to save critical materials. Such as brass, copper, aluminum. Thus the 4a parts can be steel, or cast iron. In most cases after war parts reverted to original numbers and material, according to npr. Thus the 4a radiator core could well have been steel rather than copper.
An example of change in material, is the drive disc in my sixty with the diesel conversion, the drive disc on planetary was originally aluminum, this one had a cast iron one with a 4a number. Another planetary has an aluminum one, with a casting date in the late forties.[/quote]
That is cool information. I believe the core that I have is a steel core. The tractor is a 1945 model and was originally a U.S. Military tractor.
Wed, Mar 22, 2017 7:53 PM
