D4 2T rack setting
D4 2T rack setting
bvandragt
Send a private message to bvandragt
Hello,
Could someone give me the rack setting number for a D4 serial 2T484? I have the 3H1690 gauge and know how to use it, but I don't have the settings book.
Thanks,
Brian
Sun, Feb 23, 2014 2:02 PM
cat_power
Send a private message to cat_power
i know someone who has a manual for your tractor, i will give him a call in the morning and see if he can give me the settings for you
12E motor grader
cat sixty
D6C
D6R
Sun, Feb 23, 2014 2:43 PM
Reply to cat_power:
Rack setting specs....
Mon, Feb 24, 2014 12:11 AM
bvandragt
Thanks OM. It took me a while to figure out which row of data to use. At first it looked like I needed the second row for 2T1-up, but the camshaft number didn't match what I have. My camshaft is 7B5584 which is also what the parts catalog calls for. After a while I figured that the serial numbers for the D4 on the left aren't meant to line up with the rows and that I should use whatever row matches my camshaft which is the third row. I got it set at .500.
Brian
Mon, Feb 24, 2014 10:34 AM
