D4-2T pony motor
D4-2T pony motor
Showing 1 to 6 of 6 results
Christopher
Send a private message to Christopher
My pony motor runs well but leaks like a sift. I have looked all over google trying to find a rebuild kit. Is there someone out there that sells kits for refreshing these or do I order the gaskets through my local Cat dealer?
Fri, Jul 13, 2018 7:57 AM
STEPHEN
No kits. Take it apart, look for needed part numbers from your parts book either online, Florin Tractor, your dealer, or post wants here.
Fri, Jul 13, 2018 10:55 AM
d2gary
Reply to STEPHEN:
My local cat dealer had all the seals and gaskets for a d2 pony (same engine) price was good
Fri, Jul 13, 2018 11:23 AM
TOGNOT
Reply to d2gary:
Grab your balancer on the pony motor. Try to lift it up and down. If you feel it move that seal is bad because the bearing is bad behind it. Leaks pretty good from there
Fri, Jul 13, 2018 11:59 AM
Thank you received: 77
Reply to TOGNOT:
And if you don't fix that loose play, the magneto will break so it's good motivation to fix it when identified 👍
Fri, Jul 13, 2018 8:03 PM
Christopher
Reply to TOGNOT:
Thanks. All of this is great information. I have already bought My parts book. I was kinda curios as to whether the numbers were still the same after all these years.
Sat, Jul 14, 2018 2:49 AM
Reply to Christopher:
Mostly they are. There are some supercessions but your dealer can make the cross-reference if you supply the part # from the catalog
Sat, Jul 14, 2018 5:16 AM
