D3B track rollers seized
Showing 1 to 10 of 10 results
jonstark
Send a private message to jonstark
How best can I break free then lube a couple of frozen track rollers on my D3B?
thx,
jon
1981 D3B, 1955 D7 3T, 1954 Ford Jubilee, 2001 Kubota L3010
Thu, Nov 29, 2012 8:32 PM
Jon---there is a plug on the side of the rollers that you remove and fill to that level with sae 30 oil. I would guess get the load off the roller and work it back and forth.
Thu, Nov 29, 2012 8:58 PM
Thank you received: 46
Reply to dpendzic:
If/when you get them free and they will hold oil, use the proper tool and procedure that gets oil to the inner chambers.
Fri, Nov 30, 2012 12:16 AM
Pete thanks for posting that! My maintenance manual didn't show that nozzle--perhaps because of the price??---$153.07--:jaw:
Fri, Nov 30, 2012 12:48 AM
Reply to dpendzic:
That's about right, 10 X the value of a $15 tool.
Got one off of ebay awhile ago for $10. Most folks don't know what they are not alone use one.
Comes in a protective metal tube...
Fri, Nov 30, 2012 2:47 AM
n7gxz
Send a private message to n7gxz
[quote="Old Magnet"]That's about right, 10 X the value of a $15 tool.
Comes in a protective metal tube...[/quote]
That looks like it would be easy enough to make one if you had the specs.
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Fri, Nov 30, 2012 5:24 AM
Reply to n7gxz:
Kevin
making one would be not to bad except for the o ring section at the end--Pete does all the oil flow out the end or some in the middle section?
Fri, Nov 30, 2012 6:07 AM
oldparker
Send a private message to oldparker
Reply to dpendzic:
D4 Harry has one for sale on ebay right now. Auction ends in three days.
Fri, Nov 30, 2012 6:20 AM
Reply to oldparker:
would you have the link to that?? i put in the part # and nothing came up--and there is 206 pages of parts
Fri, Nov 30, 2012 6:31 AM
Reply to dpendzic:
http://www.ebay.com/itm/Caterpillar-sealed-roller-lube-tool-d2-d4-d6-/160929651920?pt=LH_DefaultDomain_0&hash=item2578279cd0
Here's the drill...
Fri, Nov 30, 2012 6:43 AM
Thank you received: 32
some dialogue on this subject here. http://www.acmoc.org/bb/search.php?searchid=12793
OM posted some sizes for one to be fabricated.
Hope this helps--found by Advanced Search Function.
Fri, Nov 30, 2012 12:23 PM
