d3b pto
luke irons
Send a private message to luke irons
I have a friend whos trying to find if a d4d pto unit will fit a d3b. ive had a quick look on sis and cannot find any match. I don't have the serial numbers of the machines, I would probably say no but thought I best ask someone who knowsmore about these machines
regards
Thu, Feb 19, 2015 11:25 AM
Thank you received: 50
Sounds like the same request that was posted on the Heavy Equipment Forum. Same answer is they are not even close.
Thu, Feb 19, 2015 12:49 PM
luke irons
Thanks old magnet
Thu, Feb 19, 2015 1:21 PM
d4e
Send a private message to d4e
Reply to luke irons:
Thanks old magnet
Lindex made a PTO and 3 pt hitch for JD 450,550, 650. also for D3B,C tractors.There was a guy in Washington state I believe had a Lindex setup and a rotary mower on a D3.I have seen them for sale from time to time in Capitol,Press.
Sun, Feb 22, 2015 3:55 AM
Reply to d4e:
I believe this is what your looking for if you could find one. Cat never made a 540 rpm pto for the D3 but they did produce a pto drive for their winch. Requires the extra u-joint drive shaft similar to the winch drive plus the after market pto with clutch control to couple to the constant drive powershift shaft.
Sun, Feb 22, 2015 6:20 AM
