D3B Pins and bushing kit
Showing 1 to 10 of 10 results
3CATS
Send a private message to 3CATS
Hello all,
I noticed today after changing the bevel gear oil that my pins and bushings are shot on my blade😞 anyone know where I can get a set cheaper then OEM Cat parts? Also need to know what size grease tip i need, is just a needle tip?
Anyone have a jpg of the pages reguarding the lube pionts and schedule?
Thanks again!
D3B 2PCXXXXXXX
Bill
Cats >D4-5T with toolbar dozer, D3B lgp, D2-4U with electric pony start and OEM roller grease can.
Case 580B Loader
Kubota BX24 backhoe
BOBCAT 331 Excavator with hydro thumb and full cab.
Mon, Dec 3, 2012 12:27 AM
My manual does not show any lube points for the blade pins. I have also been told from Cat that they are not grease able and have to be changed when worn out.
Mon, Dec 3, 2012 1:04 AM
3CATS
Reply to dpendzic:
Thanks dp,
I don't have a manual for my D3B. I was hoping to find a pdf or jpg that shows all the grease points and lube schedule. I don't even know how to lube the idler yoke?
I only use the D3B a few times a year to plow my dirt road when the snow gets to be over 3' . I should know more about the D3B and take better care of it.
thanks
Bill
Case 580B Loader
Kubota BX24 backhoe
Mon, Dec 3, 2012 1:14 AM
Reply to 3CATS:
Thanks dp,
thanks
there are actually no grease points except for the universal joints
the idlers and rollers take sae 30w oil--rollers have a plug on the out board side and the idlers have a plug on the side of the idler near the shaft. turn them until you can see the plug in a 12 oclock position. the plug may be on the outboard side on one idler and the inboard side on the other idler.
BTW--I am not familiar with the 2PC model D3B--I know of the 23Y 1r-3F and my 27Y 3R-3f models but not that one.
Mon, Dec 3, 2012 3:01 AM
3CATS
Reply to dpendzic:
My D3B is a LGP model with the 10' blade. Great for plowing snow and pushing brush but that's about it . A few times a year we will get a 3' or 4' snowfall overnight and my dirt road is over a mile long. The d3b is the only way i can open up my road in those conditions.
Can you fill the rollers without the CAT tool?
Thanks for the help!
Bill
Case 580B Loader
Kubota BX24 backhoe
Mon, Dec 3, 2012 3:30 AM
Reply to 3CATS:
I have been filling my rollers for about 5 years with a squeeze bottle and small plastic tube--not that they needed very much oil though
Mon, Dec 3, 2012 3:56 AM
3CATS
Reply to dpendzic:
Do you need to remove the rollers? and what about the top roller?
Sorry for all the questions.......
Thanks again.
Bill
Case 580B Loader
Kubota BX24 backhoe
Mon, Dec 3, 2012 4:05 AM
Reply to 3CATS:
Thanks again.
all the rollers have a plug on the outboard side at the center of the shaft and all are accessible without removing the roller
Mon, Dec 3, 2012 4:44 AM
3CATS
Reply to dpendzic:
Thank you very much for the info dp!
Bill
Case 580B Loader
Kubota BX24 backhoe
Tue, Dec 4, 2012 1:10 AM
daron
Reply to 3CATS:
Are you? Frazier Park, Tehachapi, or Kern River area? I'm in California City. Retrieved a D45T from above Walker Basin last year with the help of Garlic Pete and his 'retrieval tools' (Peterbuilt/Trailmobile and D69U combination).
Daron
Tue, Dec 4, 2012 3:06 AM
3CATS
Reply to daron:
Daron
Daron,
Mountains above Lockwood valley Ca. 6000' elevation and 25 acres of pine tree's and rock.
I have camped there at Cal city many times with my kids riding our bikes and atv's. Great little town! I also love Jawbone...That ride from Jawbone up into the Sequoia's on the side by side ( Rino or 6x6 ) is one the best rides out here!
I will be working on my D4 5T this winter. I need one new injector and i have a leak in the Radiator.
Cheers!
Bill
Case 580B Loader
Kubota BX24 backhoe
Wed, Dec 5, 2012 12:48 AM
