D3B front idler carriages and yoke
Showing 1 to 7 of 7 results
jonstark
Send a private message to jonstark
I sheared off a couple of the bolts holding the yoke to the carriages. If I can't get them out where would be a good place to start looking for replacement carriages?
Thanks,
jon
1981 D3B, 1955 D7 3T, 1954 Ford Jubilee, 2001 Kubota L3010
Wed, Sep 14, 2011 10:22 PM
jonstark
Took oxy/acetylene to get the master pin loose and 18 pounds to beat it out. Whew!
One bolt drilled and hole cleaned up, two to go.
I am so glad I got it out of the mud hole it broke down in!
jon
[attachment=10936]dozer001.jpg[/attachment]
Wed, Sep 28, 2011 6:13 AM
jonstark
Reply to jonstark:
jon
Got all the sheared off bolts drilled out and the holes cleaned up perfectly with a tap. Reassembled the yoke and idler today. Need a new master pin and bushing then it's off to the races before the snow starts or the ground freezes up. It's been a couple nice days in the woods here. Lotsa turkey, deer and bear. The mushrooms are popping up like mad too.
jon
Thu, Sep 29, 2011 7:54 AM
Thank you received: 46
Reply to jonstark:
jon
Better check the wear on the idler bearing blocks and frame wear strips or it may happen again if the yoke is being placed in a bind.
Sat, Oct 1, 2011 11:35 PM
jonstark
I was able to tighten up the wear blocks by removing the shims. The idler axle is tight in the bearings which are also good. Hoping this doesn't happen again. Replaced the bolts on the other side as a preventive measure.
jon
Tue, Oct 4, 2011 4:20 AM
Reply to jonstark:
jon
Jon---what do you think caused this? did you hit something with front of the track, or maybe turning and hit something? also the track had a master pin and not a z bolted track link?
Tue, Oct 4, 2011 5:10 AM
Reply to dpendzic:
Those shims are just for aligning the idler, they don't do anything for vertical movement due to wear.
Tue, Oct 4, 2011 5:53 AM
jonstark
I was moving piles of sheared stumps which are taller than the Cat. I must have gotten one wedged in between the frame and track as I was diving in and out of the piles.
I knew there was already one bolt sheared and the track on that side was much looser than I ever run it. Oops. So one learns. Replace missing bolts and don't run with a floppy track.
I removed the shims to tighten the carriage onto the rail so it would be less likely to cock. The wear strips are very worn but this helped a bit at least.
I WISH this track had a master link. I would have been able to do the job single-handed that way. I needed a someone to hold the drift to hit it with the sledge. "When I nod my head you hit it!"
jon
Wed, Oct 5, 2011 3:10 AM
