D3B drive problems
D3B drive problems
68dually
Send a private message to 68dually
I was running a d3b for a friend and the left side started to disengage once in awhile. Sometimes it works and sometimes it doesn't. It seemed to get more frequent over a period of about 20 minutes. Any thoughts?
Thanks, Randy
Wed, Nov 6, 2019 6:07 AM
Couple of possibilities...
Either the clutch pack is worn to the limits or
If they are dry clutches and are getting oil contamination causing them to slip.
Wed, Nov 6, 2019 8:14 AM
