D342 injector line problem
OldRedTim
Send a private message to OldRedTim
Was about to start the D8 for the first time after replacing the head and piston.
I can't get the injection line to seal on the front injector. The nut will tighten down, but you can still wiggle the line in the nut.
I swapped in a different injector and had the same issue.
D8G 15A273
Wed, Jul 4, 2018 7:49 AM
Thank you received: 60
Check the ferrule on the end of the injection line. They have been known to split and not seat.
Wed, Jul 4, 2018 9:59 AM
OldRedTim
That's exactly what the problem was. I had another line split when I was making sure I had the lines blead.
Thu, Jul 5, 2018 1:03 AM
