d342 identity issues
joseph
Send a private message to joseph
what is the best way to tell what type or series of d342 engine one has without a tag or stamp. Is there any distinctive parts or markings on the engine other than the tags. Reason for the question is because I may need head gaskets and I don't want to tear the engine apart without knowing if i can get them.
Wed, Mar 16, 2011 7:02 AM
straycat.inc
Send a private message to straycat.inc
If the engine is in a machine, D8, start with the s/n of the machine. The s/n is located at the rear of the bevel gear case, on the upper left hand side. If there is a winch or ripper on it , the number will be covered up. You could also pull the valve covers and use the casting numbers. You won't have trouble getting your gaskets, I just ordered and recieved head gaskets for my 3T, genuine Cat, from the Cat Dealer in Northern Alberta Canada.
Wed, Mar 16, 2011 12:02 PM
ag-mike
Reply to straycat.inc:
should be a s/n stamped on the oil pan flange of the block (left side) if its not to new. i don't know when cat stopped doing that. good luck.
Wed, Mar 16, 2011 7:32 PM
catsilver
Reply to ag-mike:
The only thing you have to identify is if it is a 'spacer plate' engine to make sure you get the spacer plate gaskets as well, the head gaskets all change up to the same number for a D8H and D8K. The only other changes are the turbo and manifold gaskets.
If my memory serves me correctly and you work backwards, the current head gasket supplied to fit a three cylinder D6 and 1H/8R/2U D8 is the same as that now supplied to fit the last D342 in a D8K.
Wed, Mar 16, 2011 7:39 PM
