D342 bolt tourque specs
OldRedTim
Send a private message to OldRedTim
Getting ready to install the new cylinder head on the D342 in my D8.
Got a few questions.
What cylinder head bolt tourque spec do I need to use? My service manual lists two different specifications.
The higher tourque specs are given for "thicker hardened washers and nuts." How do I know if I have those or not?
4H9851 rod bolts fit the connecting rods with the milled flat spot under the bolt head correct?
Sun, Jun 17, 2018 8:12 AM
Thank you received: 60
I don't know how you would tell other than having samples of both selected by part number to compare.
Sun, Jun 17, 2018 10:13 PM
WA7OPY
Send a private message to WA7OPY
You will also need the torquing sequence,....WA7OPY
Mon, Jun 18, 2018 12:53 AM
