D334 engine
D334 engine
Showing 1 to 6 of 6 results
BobPV15
Send a private message to BobPV15
I am looking at a Finning genset with D334 engine SN 92B515. would any one know when this was made? Thanks
Mon, Jan 15, 2024 4:32 AM
bluox
The 92B motors came out in 1974 so 74, 75 would be my guess.
I believe that motor is a 3306 with overhead cams.
Bob
Mon, Jan 15, 2024 9:17 AM
PhilC
That is not a 3306 engine. The D334 came out in the mid to late sixties as far as I could find out (maybe even earlier like the rest of its family D330, D333 and D336). 638 cu inches so the same size as a 3306 but older technology but Bob is correct in that it does have twin overhead cams
Mon, Jan 15, 2024 4:55 PM
bluox
Reply to PhilC:
[quote="PhilC post=254056 userid=11059"]That is not a 3306 engine. The D334 came out in the mid to late sixties as far as I could find out (maybe even earlier like the rest of its family D330, D333 and D336).638 cu inches so the same size as a 3306 but older technology but Bob is correct in that it does have twin overhead cams
Nope the D334 came out in 1974 and is a 4.750 bore motor with a spacer plate,so is more like a 3306 than a D333.
Bob[/quote]
Mon, Jan 15, 2024 8:07 PM
BobPV15
Would the overhead cams be gear driven or use a timing belt. Thanks for the replies.
Tue, Jan 16, 2024 2:23 AM
Reply to BobPV15:
A little hard to read but here's a product bulletin on the net....https://www.ebay.com/itm/401707263316?chn=ps&mkevt=1&mkcid=28&srsltid=AfmBOoosK_q4Zsvx2BqQswvut_YwzDvl5oyQbn28TSg66bbdaqhUUJ_Bw18
Tue, Jan 16, 2024 2:48 AM
BobPV15
Thanks Old Magnet. So it does date back to 1967 and has all gear driven cams.
Tue, Jan 16, 2024 4:36 AM
