d330 liner counterbore problem
Showing 1 to 10 of 10 results
Justinc
Send a private message to Justinc
hi guys i need some help with my d330 the problem is my counter bore depth are to deep caterpillar calls for 400" and mine are at 447" before machining the deck the question is what can i do to bring them back to spec?
Fri, Aug 5, 2016 5:39 PM
Thank you received: 63
If you can take 007 off the deck, problem solved? (Edit - dang it. I didn't read carefully enough... : )
Fri, Aug 5, 2016 7:09 PM
d9gdon
Here is a list of liner shims to bring it back into spec:
[attachment=37235]Liner Shims 2 001.jpg[/attachment]
Fri, Aug 5, 2016 7:20 PM
Justinc
Reply to d9gdon:
[quote="d9gdon"]Here is a list of liner shims to bring it back into spec:
[/quote]
Thanks mate is .030" the thickest shim available?
Fri, Aug 5, 2016 8:21 PM
Justinc
Reply to Justinc:
[/quote]
Also can the shims be stacked?
Fri, Aug 5, 2016 8:46 PM
d9gdon
Reply to Justinc:
It is not advisable to stack shims, but my engine machinist has cut thicker shims and used them, but it seems like we were talking about a 3306.
His opinion was to avoid the thin shims for fear of exhaust gas erosion, but I always figured that Cat had done a little research on that when they designed them.
Sat, Aug 6, 2016 2:47 AM
Justinc
Reply to d9gdon:
As always great information guys i guess i may have to find a laser cutting place to cut out thicker shims or my other option is caterpillar will machine up inserts but i dont have a spare arm or leg to give up lol
Sat, Aug 6, 2016 5:59 AM
Thank you received: 34
Reply to Justinc:
Hi Justin,
maybe contact Head Hunters in Dandenong and see what they offer. They are now part of William Adams but did all of our engine machining work for years and may have done your block and supplied the shims to suit back in the day.
Sat, Aug 6, 2016 7:09 AM
tctractors
Reply to edb:
Hi Justin,
The first task to do is drop all the cylinder liners in the holes and check the "Dip" facing up the block involves topping the pistons so more work, the liner shims can be stacked if you have to but avoid using 1 thick shim and 1 very thin shim, if you do stack them use 2 shims as thick as possible to attain your height target, is this a 4"1/2 or 4"3/4 bore engine?
tctractors
Sat, Aug 6, 2016 1:42 PM
Justinc
Reply to tctractors:
tctractors
[quote="tctractors"]The first task to do is drop all the cylinder liners in the holes and check the "Dip" facing up the block involves topping the pistons so more work, the liner shims can be stacked if you have to but avoid using 1 thick shim and 1 very thin shim, if you do stack them use 2 shims as thick as possible to attain your height target, is this a 4"1/2 or 4"3/4 bore engine?
tctractors[/quote]
Thanks for your info it is a 4.5" bore
Sat, Aug 6, 2016 1:46 PM
Bob Mocha
Send a private message to Bob Mocha
Reply to Justinc:
tctractors[/quote]
I had a D7E with about that size bore and we had a guy that came to the shop and cut the block counter bore to match a cat part number shim that also squares up the bore cuz they will be uneven. Maybe check with an older shop that may have the tool. The engine stayed in the frame so no extra work on my part.
Sat, Aug 6, 2016 6:45 PM
