D330 injector pump timing
Showing 1 to 10 of 12 results
PhilC
Hello All
I have my 944 loader going but the diesel knock seems excessive. I thought maybe the injector pump timing is out and a mechanic backed up that idea. According to the book I need a 2m5219 spacer to measure the timing for each pump. I cannot get one as they are not available. Does anyone know the dimensions of the spacer so I can make one?
Also the procedure in the book has me confused as to how to adjust the timing. The book says to put the cylinder you are checking on TDC and then measure the distance to the cam follower in the injector pump and it says it should be done for all 4 cylinders. There is no mention of how or what to adjust if it is out of spec. I also can't see the reasoning behind measuring all cylinders, if one is out wouldn't they all be out?
I assume that the timing gears are correct as one tooth out there and the engine would not run smoothly and most likely overheat. It runs perfectly, no misfiring, no excess vibration, no overheating, plenty of power, easy to start, it just seems to knock more than it should. Engine had new rings, liners, main bearings, big end bearings, crankshaft ground and a new head with new valves.
Regards
Phil
Sat, Aug 22, 2020 7:15 AM
D330c pump was timed with a fixture that slips over some studs on the front cover over the pump drive gear. I believe the gear has a taper fit to end of the shaft without a key but I didn’t do it, just helped a local CAT mechanic reinstall the pump after a rebuild at the local dealership pump shop. Unfortunately the pump was never the problem as we discovered later the engine had ingested a mud dauber nest that broke up in the air intake. We found the remains of it and the small opening that had allowed the wasp to get in there and build it.
Sorry I am not more help
Sat, Aug 22, 2020 8:25 AM
Thank you received: 32
Hi Team,link below will get you all i have on this.
http://www.acmoc.org/bb/showthread.php?32258-D330-injector-pump-settings/page3&highlight=d330+rack+tooling
Sat, Aug 22, 2020 9:21 AM
PhilC
Reply to edb:
Thanks ccjersey
Thanks Eddie
Is the rack setting tool spacer the same? It has a different part number.
Regards
Phil
Sun, Aug 23, 2020 7:06 AM
Reply to PhilC:
Thanks ccjersey
Thanks Eddie
Regards
Phil
Hi Phil,
sorry I believe it was OM who said the old 8M0530 Rack setting tooling---micrometer--has been replaced by a 7S7113--I stand to be corrected as I do not recall any knowledge of this but things change--I think our micrometer had some grinding done to the loose collar to allow it to fit in some tight space applications--other than that I am in the dark too.
Sun, Aug 23, 2020 7:58 AM
Thank you received: 48
Reply to edb:
Hi Phil,
Is this what your looking for???
Sun, Aug 23, 2020 12:19 PM
PhilC
Hello OM
No sorry but thanks anyway. I am not trying to set the rack position. I have already done that. The procedure in the book for checking the timing is shown on the page below.
[attachment=60210]Manual 250.jpg[/attachment]
Sun, Aug 23, 2020 6:49 PM
Thank you received: 61
Reply to PhilC:
Hello OM
Hi Phil, the instructions you posted seem straightforward. I'm wondering if the "all four" instruction just means check the timing on all four cylinders individually i.e. go through that process described one cylinder after another, but yes, seems like a superfluous instruction. Maybe they're concerned that the wrong pump camshaft is in there, or something?
Sun, Aug 23, 2020 7:00 PM
Individual pumps are timed by changing the spacer thickness. Can be checked with mechanical indicating tooling, dial indicator with gauge and plunger or gauge and depth micrometer. The usual gauge is a 2" high plug reference set into the housing to rest on the spacer/seat.
The current plug gauge for depth micrometer use is a 8S7167, available aftermarket at $12.99.
https://aftermarket.supply/caterpillar/8s7167.html
Mon, Aug 24, 2020 12:42 AM
just to reinforce what OM has added above I add this scan as taken from a Tool Guide Book.
Now if you are looking to check the pump to engine injection timing on the engine you will need to find the Injection timing BTDC dimension from the spec. section of your Service Manual and follow a Spill Timing procedure to check it.
I will do some searching and see what I have to add if anything.
You could easily use the lifter setting on engine measurements and double check No1 pump lifter setting at least to check actual on engine pump timing.
Remember doing on engine lifter settings on a 933 engine that was hard to start when I was an Apprentice--first one I ever did--they gave me the book and said here you are lad--check this--never seen one before--got it done with success.
Mon, Aug 24, 2020 7:47 AM
PhilC
Reply to edb:
Thanks Neil, OM and Eddie.
As soon as I find my depth micrometer I will check the timing. I have made my own spacer.
Eddie, my only concern is the diesel engine knock. My 3304 does not knock anywhere near as bad. It may be normal. I have never heard a D330 running in person to compare. According to the manual the setting is done at TDC and should be 4.2264-4.2304" using the 2" spacer and a 4-5" rod in the depth micrometer.
Regards
Phil
Thu, Aug 27, 2020 5:45 PM
