D330 head repair possible?
Showing 1 to 10 of 13 results
.RC.
Send a private message to .RC.
The D330 motor in my 922 loader started blowing water out the exhaust and lots of bubble in the coolant...
Upon pulling the head I discovered some damage to the head and it appears to be leaking somewhere between the threaded insert that the pre com chamber bolts into and the valve seat insert.
Are there any repair options available?
[img]http://img.photobucket.com/albums/v606/OzRinger/20121122_132627Custom.jpg[/img]
[img]http://img.photobucket.com/albums/v606/OzRinger/20121122_132646Custom.jpg[/img]
[img]http://img.photobucket.com/albums/v606/OzRinger/20121122_132751Custom.jpg[/img]
Thu, Nov 22, 2012 12:12 PM
catsilver
I would suggest looking for a new head, it seems to have been repaired before and further repair (even if it is possible) would cost a fortune be unlikely to be successful.
Thu, Nov 22, 2012 2:26 PM
.RC.
Reply to catsilver:
Depends on what you call cost a fortune I guess...
A new bare non genuine head is $2500. It is a discontinued line for Cat... 2s9004
That is probably a 1/4 of what the machine is worth....
Fri, Nov 23, 2012 8:03 AM
invisabledog
Send a private message to invisabledog
Reply to .RC.:
http://www.offroadeq.com/ has a head for $1436.
[quote=".RC."]Depends on what you call cost a fortune I guess...
That is probably a 1/4 of what the machine is worth....[/quote]
Fri, Nov 23, 2012 8:33 AM
.RC.
Reply to invisabledog:
Problem is freight...
Fri, Nov 23, 2012 9:03 AM
d9gdon
Reply to .RC.:
.RC. where are u located in these States?
They made thousands upon thousands of these engines so a rebuilt one is not far from you. I don't think you'll get that one reworked cheaper.
Now I see you're in Australia after I made my post. There are several guys from your part who can steer you in the right direction, just give it a little time.
Fri, Nov 23, 2012 9:08 AM
Mike Walsh
Reply to .RC.:
Where are you located. There's two cores on CL. Maybe someone can help you salvage one of these and there's enough there to reduce the cost of your head.
Coos Bay, OR. http://oregoncoast.craigslist.org/boa/3417200792.html
Detroit, MI. http://detroit.craigslist.org/mcb/for/3336212811.htm
Fri, Nov 23, 2012 9:11 AM
.RC.
Reply to Mike Walsh:
Australia, hence the problem with freight...
Fri, Nov 23, 2012 9:14 AM
That probably could be repaired by someone who has experience with cast iron welding and a way to preheat the whole head in a furnace, do the repair, return the head to the furnace and let it cool slowly over hours. They would also have to remove the valve seat ahead of time and machine the welded area afterwards and replace the seat. I had a couple of Yanmar heads repaired last year that had cracks in the same area. One was entirely satisfactory, but the other had a new crack in another, less critical area when we finally got it reassembled. Had so much trouble getting the heads back from the shop, I really didn't want to send it back to them, so it's running with some block sealer and doing fine.
Unless you 're close to someone who does that kind of work, I would look for another head.
I thought I was looking for a D330 a couple years ago when I found a 922 in the weeds, but it turned out to have the D322 with a turbo. Have an old 944 that does have the D330 that we still run. Wonder if you might find a generator set with a compatable engine somewhere for not much more than the cost of just the head. I have one with a D330C that got "dusted" and needs an overhaul.
Fri, Nov 23, 2012 9:33 AM
Inter674
I gues you have tried Tilly's or cat expert and parts guru David Tillyard (03 62681335) down in Tassie - he might have one.
Fri, Nov 23, 2012 11:53 AM
.RC.
Reply to Inter674:
Have managed to get one from a place called Catamac.
Caterpillar have none available anywhere in the world, either new or reman...
Sat, Nov 24, 2012 3:36 AM
