D330 C - Calling Old Magnet Once Again
ms0115
Send a private message to ms0115
D330 C
Serial # 4B1888 Industrial
The water pump number I gave you yesterday is the incorrect pump. The pump I have, has a water inlet that goes straight to the cooler and one that goes to the thermostat housing. The one just purchased is made different. Do you happen to know what the seal number for the pump should be? Thanks
Wed, Feb 15, 2017 12:14 AM
You better get me a picture of what water pump you are referring to. Is the pump for engine cooling, auxiliary pump or raw water pump? I have the parts book for the 2Bxxxx normally aspirated engine where the 4Bxxxx is turbo. Same parts otherwise.
Here is the parts diagram for the standard engine cooling pump. Auxiliary drive pump also uses the same seal.
Wed, Feb 15, 2017 1:44 AM
catsilver
That looks like a marine keel cooling pump to me OM, check the engine arrangement that it fits with.
Wed, Feb 15, 2017 4:09 AM
Reply to catsilver:
What arrangement number? 2Bxxxx is non turbo Industrial, 4Bxxxx is turbo Industrial, 5Bxxxx is marine.
Could be auxiliary drive water pump which is very similar.
Wed, Feb 15, 2017 4:29 AM
ms0115
[quote="Old Magnet"]You better get me a picture of what water pump you are referring to. Is the pump for engine cooling, auxiliary pump or raw water pump? I have the parts book for the 2Bxxxx normally aspirated engine where the 4Bxxxx is turbo. Same parts otherwise.
Here is the parts diagram for the standard engine cooling pump. Auxiliary drive pump also uses the same seal.[/quote]
It is for engine cooling. It has a bolt on elbow that goes to the oil cooler and then has a smaller separate line that goes to the thermostat housing. The picture you sent might be right, but I need to see a picture of the top. Both lines go into separate parts of the pump.
Wed, Feb 15, 2017 5:16 AM
Reply to ms0115:
I don't have a picture of the top but the connection would be a two bolt elbow to a hose connection to the oil cooler line and there is a small diameter tube going from the elbow to the thermostat housing.
Found a picture....
Wed, Feb 15, 2017 5:29 AM
ms0115
Found a picture....
[quote="Old Magnet"]I don't have a picture of the top but the connection would be a two bolt elbow to a hose connection to the oil cooler line and there is a small diameter tube going from the elbow to the thermostat housing.
Found a picture....[/quote]
Old Magnet, I went to the mill to get pictures, but the picture you sent is correct. So I think the seal # in the picture should be correct; However I would still like to find a complete new pump. Any ideas on numbers to try?
Wed, Feb 15, 2017 7:36 AM
Reply to ms0115:
I looked around the internet for a 7L0144 pump and could not find a source. Might try Cat for pump or parts to rebuild. I think aftermarket listings that show the D330C and 3304 as being interchangeable are misleading. Something to do with the lost transformation between the two engines. They sure don't interchange in the parts break downs. You may be limited to used or rebuilt units.
Wed, Feb 15, 2017 7:59 AM
ms0115
Old Magnet,
Called the CAT dealer and they said there was not a rebuild kit in the United States at this time. I would be happy with a used or reman. unit. My reasoning for another pump is that I could get this one built up for a spare. This power unit is on my sawmill, run by the Amish ,cutting crossties, and they don't like down time. Thanks for the help.
Wed, Feb 15, 2017 9:04 AM
