D330 C - Calling Old Magnet
Showing 1 to 9 of 9 results
ms0115
Send a private message to ms0115
D330 C
Serial # 4B1888
Found the water pump for it; They were running it this morning and the fuel transfer pump has gone out. Do you know of any other engines that carry the same pump to help me locate it easier. Thanks for any help and assistance you can give.
Thu, Feb 9, 2017 11:05 PM
Takes a #4N4878 pump. Check ebay
Thu, Feb 9, 2017 11:56 PM
ms0115
Thanks once again for the help.
Fri, Feb 10, 2017 12:01 AM
Reply to ms0115:
What was the water pump part number that you used?
Fri, Feb 10, 2017 12:02 AM
ms0115
I do not have the number in front of me right this minute, but I will send it to you later. Thanks again for the help.
Fri, Feb 10, 2017 3:28 AM
Reply to ms0115:
OK, thanks, would like to add to my files.
Fri, Feb 10, 2017 3:45 AM
ms0115
The waterpump was 1727767.
And the fuel pump was like you said 4N4878.
Thanks again for all your help.
Tue, Feb 14, 2017 5:13 AM
Reply to ms0115:
OK thanks,
The original D330C water pump is different than that of the 3304 unit but apparently they will interchange.
Tue, Feb 14, 2017 6:29 AM
L364
Send a private message to L364
OK thanks,
Hello
From what I can remember the D330C & 3304 jacket water pumps can not
be interchanged, i.e. the D330C pump is gear driven through the side of the
front timing gear housing and the 3304 pump is gear driven through the
front of the front timing gear housing.
Tue, Feb 14, 2017 6:08 PM
Reply to L364:
Hello
My parts books show both D330C and 3304 engines to be poke the pump in the hole, not side mount.
I'm a little leary of interchange as the outer bearing support appears different between the two but aftermarket does show some interchange between D330C and 3304. Could be it only applies to some industrial engine versions.
Wed, Feb 15, 2017 1:48 AM
