D318 Valve Lifter Guides
scotia
Send a private message to scotia
The each of the valve lifter guides are held in by four bolts, two of which are ground finished for aligning purposes. Question is do these ground finished bolts go on the top or the bottom. The parts book illustration does not show wheather they go on the top or the bottom nor the service manual. The ones on my machine have been put in willy nilly.
Thanks for your response in advance.
Fri, Dec 11, 2009 9:27 AM
My parts book shows S-1594 on top and 4B6697 on bottom. I don't know which is which though.
Fri, Dec 11, 2009 9:56 AM
They actually change location depending on your engine serial number??. Check your parts book. The S-1594 is a standard 3/8 x 1 in. x 16 tpi cap screw. The 4B6697 is 1-1/8 in. length.
Fri, Dec 11, 2009 10:06 AM
scotia
Thanks for the response. I do not know what I was looking at before in the parts book but now I see that the 4B6997 goes on the bottom. Strange that the parts book lists a quantity of 9 for each. There are 6 of these guides with 4 bolt holes each.
Thanks for your response.
Fri, Dec 11, 2009 12:10 PM
Reply to scotia:
My parts books show 12 and 12. For the 9U.
The 5V industrial engine shows 10 & 10, probably because it shares mounting of some other component.
Fri, Dec 11, 2009 11:15 PM
Thank you received: 95
from memory the holes for the dowels are diagonally opposite each other in the covers and maybe a tighter fit for the dowel bolts, I cannot recall if the holes in the block are counter bored to take the dowels also and therefore become evident when inspected.
As OM said, geny covers and wiring looms and etc. attach in some locations with spacers and longer bolts.
Just my 0.20c worth to check and maybe assist or not.
Sat, Dec 12, 2009 8:15 AM
