D318 pony starter motor
hookblock
Send a private message to hookblock
Looking for some info on removing the starter on a D318 pony motor, serial# 5v17256. The motor is in a bucyrus erie 22b. Thanks
Sun, Jul 11, 2010 6:15 AM
There's a great big bolt with a lock nut on it on the top side of the starter motor that holds it in the housing so it can engage the gear when you turn it on. Loosen the bolt and wiggle it out of the hole in the housing. Might have to spray some rust buster in the hole and do some tapping with a small hammer etc to get it out.
Think of the housing that has the pulley for the belt being like the bell housing of a larger engine with the starter mounted in a hole and engaging the flywheel. The D318 pony starter is the same, just smaller.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Sun, Jul 11, 2010 11:00 AM
hookblock
Thanks for the info, I don't have a book for a D318 yet, I hope to give it a try today.
Sun, Jul 11, 2010 9:20 PM
hookblock
Reply to hookblock:
A follow up on the starter, I got it out but not without breaking the casting where one of the 2 long bolts holds the two halves together. Is this a cat part or is it something I can get at napa?
Mon, Jul 19, 2010 7:46 AM
Thank you received: 52
Reply to hookblock:
That's a Cat part and I'm pretty sure your going to have to shop used.
Pt # 9B8851 if the starter has the solenoid switch mounting.
Pt # 9B8863 if it has the manual push button switch mounting.
Mon, Jul 19, 2010 8:03 AM
hookblock
Thanks OM, looks like I am looking for part #9B8851
Mon, Jul 19, 2010 8:13 AM
hookblock
Reply to hookblock:
OM, is part #9B8851 just the nose cone?
Sun, Aug 1, 2010 12:35 AM
Yes, that is the nose housing of the starter motor 7B2421. That is the only one listed in my late D6 parts book. It has the solenoid on it.
Sun, Aug 1, 2010 1:38 AM
hookblock
Thank-you, sorry no parts book yet ๐Ÿ˜ž
Sun, Aug 1, 2010 8:08 AM
