D318 pony
D318 pony
Showing 1 to 10 of 11 results
Tugger
Send a private message to Tugger
Hi
Im looking for some advice.The pony on the 318 in my Bucyrus 22B shows a bit of anti freeze when you open the L. H. drain cock. Im actually just headed out on a job with it,so ive changed oil in the pony,i have a D2 thats ran for years with a similar afliction. Will head gaskets solve this or is it a major?
Fri, Dec 15, 2017 12:00 PM
rmyram
head gaskets should solve it, i have a d6 that does the same thing on the same thing n the same cylinder, i just leave the petcock open to make sure it doesn't accumulate and rust the cylinder.
Fri, Dec 15, 2017 12:39 PM
A new head gasket is cheap. I have one that is rusted from persistent leakage........should have fixed it long ago. Now I have a weak pony.
Fri, Dec 15, 2017 10:56 PM
Thank you received: 288
Reply to rmyram:
I have a 12 blade that has a small coolant leak too. I will openly admit that I have procrastinated in replacing the head gasket. I do make sure the draincock is open so it doesn’t fill up the cylinder and do more damage. Just be sure to have it open to clear anything, as antifreeze doesn’t burn too well; I crank the pony a round or two until I hear it pop, then close the valve. Runs good otherwise. JM
Sat, Dec 16, 2017 12:03 AM
Tugger
Thanks guys.Any ideas on sources for parts here in Canada?
Sat, Dec 16, 2017 9:11 AM
cheshire cat
Send a private message to cheshire cat
Reply to Tugger:
Finnings !! or local aftermarket parts place ..
Sat, Dec 16, 2017 3:41 PM
STEPHEN
Reply to cheshire cat:
When I have warped pony heads I flatten them on the surface grinder. Have it checked when you go for the new gasket.
Sat, Dec 16, 2017 10:24 PM
mog5858
Reply to STEPHEN:
most simple thing is to re-check the head bolt too see if there tight? i think where to be in the 80 foot/ lb ' rage that just off the top of my head i would look it up first.
Sun, Dec 17, 2017 2:30 AM
Tugger
Reply to mog5858:
Thanks Mog . ill start there. I put the old girl to work today ,years of not being working and idling made for a shower of oil slobber. I hope that quits with some load on the engine.
Sun, Dec 17, 2017 8:16 AM
Thank you received: 93
Reply to Tugger:
Hi,
chart gives torque for early pony motors.
55 lb/ft for D318 pony motors.
Hope this helps.
Sun, Dec 17, 2017 9:05 AM
old-iron-habit
Reply to Tugger:
I think that is one time when it really makes sense to wear a cowboy hat. :redface: :redface: Work it hard for 4 hours with the engine a operating temperature and don't look at the ducks flying by. I would bet it clears up fine.
Mon, Dec 18, 2017 3:19 AM
