d318 cat engine
d318 cat engine
Showing 1 to 7 of 7 results
jw45
Send a private message to jw45
what is the valve adjusting sequence for this engine thanks jw45
Wed, Feb 11, 2009 7:43 AM
Flywheel should have marks with cylinder pairs 1&6, 5&2, and 3&4, but be aware that the flywheel can be installed incorrectly.
Wed, Feb 11, 2009 9:06 AM
bob
Send a private message to bob
The best way to be sure is to watch the rocker arms. At TDC one set will have clearance and the mateing set will be "On the rock" meaning Exh closeing and Intake opening. You can put #6 rockers on the rock and set#1 I&E,#2 I,#3 E.#4 I and #5 E. Then turn the crank 360 Deg and set #6 I&E,#5 I,#4 E,#3 I and #2 E or set them individually as you bring each piston to TDC.
Later Bob
Wed, Feb 11, 2009 10:19 PM
jw45
Reply to bob:
Later Bob
just where are you suppose to look for these marks is thier a cover hole or look through where you adjust the clutch
Mon, Feb 16, 2009 1:53 AM
Reply to jw45:
Right front side of the clutch housing sort of near the engine oil dipstick.
look for a small cover held on by a couple of bolts. Should be a pointer in there and marks on the front of the flywheel. You can do it all from the top if you want, just watching the rocker arms like Bob says.
Mon, Feb 16, 2009 7:12 AM
jw45
thanks for the answers while i had the head off i marked tdc on #1to adjust by what i was doing was to see if all the marks lined up properly for future use thanks for the help jw45
Mon, Feb 16, 2009 8:47 PM
SJ
Send a private message to SJ
Reply to jw45:
JW, be careful just because the marks says it,s on the certain cylinder doesn,t mean it,s TDC firing stroke so the valves has to be loose for the TDC (compression stroke) to set the valves and the second time around on TDC is the exhaust stroke and not the time to set the valves.Once you get the #1 on TDC to set then as stated go to the regular firing order 1-5-3-6-2-4 and set each one in that order. Make sure you turn the flywheel CCW if you,d be setting in the seat of the tractor.
Tue, Feb 17, 2009 2:12 AM
SJ
Reply to jw45:
Tue, Feb 17, 2009 2:18 AM
