D315 pony coolant bypass
K100
Send a private message to K100
Hello. Does anyone have a source for coolant bypass parts if the pony engine is removed?
Sat, Dec 27, 2025 12:26 AM
Thank you received: 287
Most conversions are done using homemade block off plates etc. I’m not aware of any particular place that sells anything other than the electric parts.
I believe most of the block-offs you can trace with the old gasket and cut out with 3/16” sheet metal. Make your own gaskets or use dealer supplied. Someone can correct me if I’m wrong.
What was it you planned on changing? JM
Sat, Dec 27, 2025 1:33 AM
